3SGTE Rav4
Re: 3SGTE Rav4
Postby st185rc » Sun Mar 03, 2013 7:27 pm
Damn that compressor wheel looks pretty chewed up. Like a girl with chewed up finger nails....
st185rc
Re: 3SGTE Rav4
Postby phattyduck » Mon Mar 04, 2013 4:53 pm
jacubillo wrote:Ok, I just bought a 50cm breaker bar and the bolt (regular thread) came out easily.
But I still can't get the pulley out! :shrug:
It seems to be stuck in there... is there any special tool or something else I need to get this thing out of my way?!?!
552
Sorry if I ask lots of questions... I'm mechanically inclined but this is the first time I get into rebuilding an engine.
Should I just spray some WD40 and leave it soaking overnight?
I know it is too late now... but you should use a pulley puller, not the generic puller.
More like this:
There is a rubber section between the pulley hub and outer pulley that can be damaged if you use the generic jaw puller.
-Charlie
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Re: 3SGTE Rav4
Postby jacubillo » Mon Mar 04, 2013 11:57 pm
I'll keep in mind the suggestion on the pulley puller! Thkz!
BTW, Some of the parts that I've been pulling apart have some minor surface rust or corrosion. I want to keep dissasembling the engine and clean every part that I take apart, put it in a cardboard box with the part info, and store it until I reassemble the engine.
Any recommendations to remove this rust/corrosion from the parts? And should I store them in cardboard boxes with some silica gel baggies to remove moisture?
- Juan
1997 Rav4
Soon to be 3SGTE swaped...
Soon to be AWD converted...
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby SXA10 » Wed Mar 13, 2013 2:11 pm
I have a 3sgte powered Rav4...check out my blog for info.
rav4gtt.wordpress.com
SXA10
Re: 3SGTE Rav4
Postby kaijufenrir » Thu Mar 21, 2013 2:45 am
I want to do the same thing!
kaijufenrir
1997 Toyota Rav 4
Re: 3SGTE Rav4
Postby jacubillo » Tue Apr 02, 2013 12:39 am
Ok, status update:
I have been removing parts from the engine while taking LOTS of pictures.
Timing belts:
645
Removing the flexplate blots. Notice the wrench holding the flexplate steady. I used the pin as a support to jam it in place.
646
Camgears removed. Main belt was removed as well:
647
Current status of the engine: Hidraulic pump was also removed:
650
Now I need to remove the tensioner pulley assembly but there is this weird nut holding it in place. It seems like I need an oversized (#10) allen key. Is there anything I'm missing to remove this?:
648
649
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby MWP » Tue Apr 02, 2013 4:45 am
Buy yourself an engine stand :doh:
MWP
Re: 3SGTE Rav4
Postby jacubillo » Tue Apr 02, 2013 12:47 pm
I know... But they are too expensive in Costa Rica. $250 for a new one.
I need to source a used one...
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby jacubillo » Wed Apr 03, 2013 4:41 am
Update
WaterPump is now out:
652
The crank VR sensor and the timming gear:
653
Removing the crank timming gear:
655
My humble and current toolset:
651
Question:
What's better?... to now remove parts from the bottom of the block (oilpan, main bearings, etc) or from the top (head, cams, etc)?
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby MWP » Wed Apr 03, 2013 12:10 pm
Top first.
MWP
Re: 3SGTE Rav4
Postby jacubillo » Wed Apr 03, 2013 11:41 pm
Guess What?
I FINALLY got an engine stand :D
656
Time to remove the head... I'm crossing my fingers hoping theres no internal damage on the cilinders or valves due to the damaged turbo metal pieces.
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby jacubillo » Wed Apr 03, 2013 11:44 pm
PD.
Any tips/advice/suggestions are GREATLY welcome. I barely have an idea about what I'm doing. :|
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby MWP » Thu Apr 04, 2013 12:29 am
So why are you doing this?
3SGTE's aren't exactly the best engine to learn on, they are rather temperamental :(
http://gt4.mwp.id.au/
Look at the ST205 manuals (not the ST215 manual, its not very good).
There are step-by-step guides in those to removing & rebuilding everything.
MWP
Re: 3SGTE Rav4
Postby jacubillo » Thu Apr 04, 2013 2:25 pm
MWP wrote:So why are you doing this?
Mostly because that's the engine that fits in the car I have for this project and also because when I started I had NO idea what I was getting into.
Thanks for the link with documentation. It will come in handy.
1997 Rav4
jacubillo
Images: 16
Re: 3SGTE Rav4
Postby MWP » Thu Apr 04, 2013 3:51 pm
Pull off the head and dont go any further.
If you start pulling down the bottom end, or cams, etc you could get yourself into trouble pretty quickly.
If the bores arent scored badly, then you dont need to touch the bottom end.
Take the head to a dedicated head shop (not your local mechanic!), and have them deck it, and check valve clearances.
MWP
