Need an alternative to plastic intake hose!!
celica_3sgte
How about a straight intake and battery relocation?? This is mine without the use of afm.
celica_3sgte
I have a st205 now. They sell adapter for the maf. Something like this.
celica_3sgte
A few options out there, none of which are friendly with the pocket book. Not worth it if you're just looking for an intake upgrade.
Corey
Easiest and least expensive way to eliminate that aweful AFM - upgrade to a gen 3 EFI system (MR2 or 205)
Will cost ~500$ and you can find the parts on MR2OC.com and you can get the adapter harness you need from Dr. Tweak.
This is THE BEST upgrade you can do to this car IMHO - I wish I did it the day I got my car.
Here is a thread with some info to get you started.
http://www.mr2oc.com/showthread.php?t=2 ... ight=ishii
