Anyone know if there is some sort of documentation to the "history" to the HKS stuff? I know it's pretty standard stuff over in Japan, and since I have an older timer I was going to get the matching EVC from the same generation, but I can't seem to figure out a good way to look it up.
Basically I have an older timer (I believe it's the turbo timer 3 or 4) and wanted to get the boost controller that matches it. Either the EVC 3 or 4. Mainly because I've worked with them before and I think they're a good enough match for the time period of the car. If that makes sense...
Anyway... while I was trying to put the various timers in order, I realized I couldn't really find enough info about the older stuff.
(all these pictures were shamelessly stolen from around the internet)
1?
2?
Then they moved to a center oriented LCD and the multifunction-like setup...
Pretty sure this is 3:
4:
Then they did a redesign in there to update the look considerably, I believe this would be 5, and possibly 6:
Then they split the display off and had a seperate control unit:
I think there was a 7 in here somewhere, but then they started calling it "Type 0/1" or whatever...
Sound about right? Am I missing something important? I think I have the 3, although I'd have to dig it out to make sure it's not a 4. The EVC is numbered similarly, however they go all the way up to 9. Do the numbers match up as easily as they appear to? Like the EVC 3 corrosponds to the Turbo Timer 3?
1?
2?
4:
