So last summer (2012) I was lucky enough to purchase Perry's st165, which he's owned since new in 1988 :shock: . The car then stay at my buddy Frantz' (gt4times2) until earlier this month when I was able to trailer it from S. Florida to N. Georgia. I'm pretty excited about the car and the opportunity to continue adding to the history and reputation it already has.
My goal for the car is simply for it to reflect my taste, while making it "better, stronger, faster"; not easy or cheap considering that Perry only used the best of what was available at the time the car was being developed (circa 1990's through early 2000's). I'm really challenging myself to see how far I can develop the car, in it's entirety, while preserving it's original identity/personality (hafi keep it raw!). I haven't been able to resist fondling her, so I've done some changes already; just to keep myself sane! I'll update and share my progress as time permits and will try to answer some of the questions we've all had over the years about the previous build
Here is the list of mods on the car when I got it, but keep in mind that most of these were done back in the day. The engine was recently rebuilt and has ~300 miles on it:
Snapped these pics last summer in S. FL when I first got her.
Loaded and ready for Geogia..
- -Toyomoto 2.2L stroker
-Toyomoto custom fuel rail
-Toyomoto custom side entry intake mani
-Toyomoto custom headers (modified for vband)
-Toyomoto adjustable cam gears
-Turbonetics T-64 p-trim/.70 divided housing (changed to Comp Turbo Billet triple BB 6765)
-Turbonetics 42mm Racegate (changed to Tial 44mm vband wastegate)
-BBK 75mm throttle body
-Adjustable fuel pressure regulator
-Blueprinted 3SGTE bottom end
-JE pistons (86.5)
-Cunningham rods (custom length for better r/r)
-Oil Pump (camry) shimmed for more pressure
-Transmission cooler
-Toyomoto custom crank bearing mod
-ST205 tranny
-Clutchmaster twin disk clutch
-Haltech E6k Engine Management System
-Greddy profec B boost controller
-Greddy turbo timer (removed)
-Greddy fuel pressure guage
-Greddy exhaust temp. guage
-Greddy boost guage
-TRD shifter
-MSD 6A
-MSD coil
-TRD spark plug wires
-TRD struts (fronts are Koni adjustabe)
-TRD springs
-Konig Monsoon 18" wheels (215/35/18)
-Stainless steel brake lines
-Stainless steel clutch line
-Heat treated/cross-drilled rotors (front/rear) (fronts are now 13" 2 pcs w/Wilwood calipers)
-PBR red rear pads
-Accel 850cc injectors
-HKS 272 cams
-Race ported and polished head
-TVIS removed and ported to match head
-Shimless bucket conversion
-Coolant passages enlarged in head
-Ferrea valve springs
-Ferrea titanium retainers
-Dual Walbro 255 fuel pumps
-8 from tank > -8 filter > Aeromotive FPR > Dual -8 feed to rail w/ -6 return
-Mocal oil cooler
-HKS 3 core front mount intercooler
-Greddy type-r BOV (replaced with Turbonetics Raptor BOV)
-3" turbo back to Magnaflow 3" muffler (very loud, but sounds sooo good!)
