Cheaper Alternative Braided Steel ST165 Clutch Line?
de_engineered
Seems the going rate for a ST165 transmission braided steel clutch line is about $60, example here.
By comparison, my WRX line was just $25. The Celica one looks no longer or more complicated than that or any other line I've seen.
Is there another (and cheaper!) make/model's line that will fit the connectors? I feel like getting a custom line made might even be cheaper
de_engineered
CMS-GT4":2ikdjtd8 said:
I assume you could build one yourself like one would for brake lines.
That's what I was thinking. I'll have to see what they go for in one-off, and maybe see if folks here wana do a group buy. I'll get back here with the estimates when I get them.
Anyone know off hand the connector styles?
de_engineered
alltracman78":12ekjp55 said:
Why waste $25 on it?
Just use the stock one.
It made a difference in my WRX - bit apples to oranges, but idea remains the same. And there are worse ways to spend $25 after all.
phattyduck
Why waste $100 on stainless brake lines? Oh, wait...
It does help if you have a heavy duty pressure plate.
-Charlie
de_engineered
-Charlie
Exactly. This is part of my Camry build, which will get some heavier built internals as time goes on, so this is just part of that upgrade path.
