what Is needed to be done to a 98+ 5sfe block to create a 5sgte stroker.
I am under the impression that crank journals need to be ground and the obvious deck, bore and hone(s).
I am also aware of the grinding to the casting in the rear.
but is there anything that I'm missing over that is unnecessary on the 97 and below blocks?
I know all of our accessories will bolt to a pre-97 block.
I don't have a block infront of me to compare as I am weighing out going pre-97 or 98+
