Front struts are easy to find; the rear struts are PITA for AWD cars... From FWD to AWD the front struts are identical but rear struts are no same-same. My last 165 had some KYB strut inserts on it, seemed to ride nice and are easier to find.
FWD struts will fit FWD cars whatever trim option you have; ST, GT, GTS. Toyota didn't change the suspension much between models; what got changed was engine, trans, interior bits and options like radio, cruise, A/C and so on. Each manufacturer is like that; Civics share so many parts across the trim levels (CX, DX, LX, Si...) it's insane. The main difference was the engine, trans and the Si models have rear disc brakes.
So:
Front struts fit all models, yes. Rear struts are different from FWD to AWD cars.
