you know wilwood is not made in usa.
http://www.tradeinfo365.com/NorthAmeric ... ERING.html
sainz":15evyl1e said:you know wilwood is not made in usa.
ALLensTRAC":3n6d9w7g said:sainz":3n6d9w7g said:you know wilwood is not made in usa.
Honestly not much is made in the US anymore unfortunately. The wilwood calipers have proven themselves time and time again in real motorsports competition. I'd like to see the same from Ksport or D2. The only downfall you here regarding Wilwood is caliper flex although that's not common.
To gt4lm I would also look into an adjustable prop valve as increased pedal travel has been reported with this setup. It looks like you are on the right path though!!
gt4lm":1vy8mp2b said:ALLensTRAC":1vy8mp2b said:sainz":1vy8mp2b said:you know wilwood is not made in usa.
Yes it seems the prop valve is a must at that point
Wilwoodbrakes have one as do a few other suppliers
I'm probably going to get solid rear discs and slotted front but will wait till my guy gives me his thoughts befor I run around spending to much
Personally for a street car I would go with solid face front and rear. Anymore the quality of pads make all the difference and that's where I would spend the money. After installing if you get pad "ghosting" then you may require a different compound. Any slotting and drilling compromises the integrity of the rotor. To me it's not worth it.
