hacker_720
Luke, how much did that cost you?
And for sure everyone it right, the hardest part is the oil lines. you can mod the first gen oil line and try and make it work, but somehow it always fails. I also would like to get in on one of these kits, be it Lukes or Dannys. In case any of you thought this was expensive, I went to Toyota and asked about the oil feed/return lines. The small one (the 6" on with the crinkles) was $248.00 and the large return line was $275 (+/- a couple of bucks) so $500.00 for the stock line that doesn’t fit, that you have to grind and screw around with, and it will probably leak when you are done. Right now I have rubber lines on mine and they are leaking, I have two hose clamps per end and they still leak. We definitely need these kits.
