UtahSleeper
So, I imagine the diagnostics will be similar for most motors, but this question is in regards to a st215 motor I have installed and running in a st165.
Up until today, the car started and seemed to drive fine. Today it doesn't want to rev. If you push the gas to the ground it tries to do die. I can feather it a little and get the revs between 2k and 3k.
Torque is telling me code P0135, IIRC, which is just o2 heater so shouldn't cause an issue. Torque also seems to give me a vacuum reading, so I dont imagine it would be the map sensor.
Any assistance is appreciated.
