pintoBC_3sgte
Looks good Corey ! Coming to the ogopogo this summer??
Let me know if you decide to sell the 16x7's, I think I might have a good future home for them.
Corey Darling":257ouxfg said:The wheels and TTE mirrors have arrived. I'll post up pictures of the wheels once tires and mounted and on the car.
The mirrors leave a lot to be desired. As was described by others who have purchased them recently, they require work to fit them to the car. In addition, the left and right mirrors are not "mirror" copies of each other. They are very different when placed side by side.
The mirror glass used is nice, however it was very poorly cut out, the corners are too rounded compared to the FG housing, leaving gaps.
It's going to take a cutting wheel and some resin to trim the mirrors to make them more symetrical with each other, and to remove excess material along the bottom of the mirror which is preventing it from even fitting to the door.
From what I understand, this is so they can be fitted to all 3 models of GT4. But that said, for 250$ plus shipping (I combined it with my wheels in this case, but they quoted me 75 pounds to ship to Canada) they are very expensive. For the price I was expecting something better finished.
underscore":3afsghqi said:The new wheels look great! You need a comparison shot for your signature.
CSAlltrac":3afsghqi said:Car is nice and tidy man. Its nice when even the inner 1/4 panels are solid and clean. If your panels are out still do yourself and the car a favor. There is a wax product that can be sprayed down into all those hard to see areas and it will leach into everything and seal/protect it. I did my rockers, Both quarters, and front aprons on my car. If the areas were to ever see water again it will just bead off rather than sit and cause issues. BMW uses it a lot on their vehicles, its actually the substance that you can see dripping down the rocker on some older cars. Link Below
http://3mcollision.com/3m-rust-fighter-i-08892.html
