bluescapegoat
I bought the car used, previous owner said a shop told him it needed an injector for cylinder #4.
I did a full tune up, had the injectors cleaned, and still running on 3 cylinders. We traced the issue back to the ECU, which isn't sending out a signal for the injector to pulse.
The current ECU in the car has an ATS rom tune, according to the previous owner. I have not removed the ECU yet to check.
Could the rom tune cause this issue?
If I get another 91 USDM ECU, can I swap the ROM chip to the new ECU to carry the tune over?
