mkernz22":33mlkjc6 said:Clamp visegrips on the soft part of the line, it'll keep the fluid from leaking out.
Rallly":3p9bk1o6 said:mkernz22":3p9bk1o6 said:Clamp visegrips on the soft part of the line, it'll keep the fluid from leaking out.
They are Stainless steel
zaluss":1ubnkdbd said:Rallly":1ubnkdbd said:mkernz22":1ubnkdbd said:Clamp visegrips on the soft part of the line, it'll keep the fluid from leaking out.
I had the same issue. If you tie the stainless brakeline upright, it shouldn't leak too much. I wouldn't leave it overnight though.
mkernz22":34ttzvtc said:Only other thing I can think of would be to get a bolt that fits through the hole and get a nut on the other side, two regular washers and two crush washers on the inside, and tighten it down. Theoretically should create the same effect as if it was bolted down to the caliper.
