Hello guys!
Im looking into upgrading my WTA setup now till summer and wanted to ask you guys for your opinions.
Found a heat exchanger thats supposedly a 4 pass one. I know thats really bad for flow, but its roughly twice as thick as the ST185 heat exchanger (51mm). I have tried to find specs on our oem WTA water pump but have not been able to find flow/pressure data about it.
Well if the 4 pass one would be a terrible idea, is it not possible to use a ATA dual pass IC as a heat exchanger? And mod it with some valves and such for easy air/water evacuation. It might not have as many cooling stacks but they have that same WWW mesh on the inside that they have on the outside, that should help with the heat dissipation?
I also wanted to check with you guys about voltage boosting our pumps, tried to search for that too but it doesnt seem to be a popular topic? Im thinking about 13,5v for a start to give it a bit more oomph.
Not so interested in the ST205 heat exchanger. Looking for better options if such exist, something good for a very hot summer days and around 400bhp.
Im not to knowledgeable about this flow/pressure thing with our pumps but i hope you can chip in with some ideas and or recomendations (ST205 IC is incoming)
