quieter":1jaqi7y4 said:there will be less restriction because you are changing your exhaust, on a 2nd gen go for max 14 psi
quieter":2uvajcgw said:better off adding a flexi or getting a berk downpipe. id go 3 inch all the way in case you want to do big power one day. careful with the ebay dp i heard the wastegate can get stuck on them. also be careful with 14 psi, your headgasket may fail one day.
quieter":1bn2zcb9 said:from your turbo theres a nipple on the side of your air intake, connect a air hose from that nipple to the bottom of your MBC then connect another air hose from the side of your MBC to your wastegate which controls the valve in your turbo. do not forget to block off the other nipple going towards the driver on the wastegate with a blank
quieter":22je9nme said:it should be ok for the DP and yeah exactly that nipple!!
quieter":1i4etfnb said:better off adding a flexi or getting a berk downpipe. id go 3 inch all the way in case you want to do big power one day. careful with the ebay dp i heard the wastegate can get stuck on them. also be careful with 14 psi, your headgasket may fail one day.
