Hi All,
i'm restoring my st185 that was sitting in the garage for almost 10 years, after fixing a broken ecu and rewiring the distributor the car now runs fine.
the only problem i'm facing is that the engine does hesitate a bit while accelerating, i don't know how to explain it in english, but if i'm at idle (which is good) and i floor the gas, the car tend to stall and then rev.
If i give it little gas the car doesn't do it.
It seems to me like a lean situation, i've checked the manifold for leak and fixed a few one but nothing changed.
I've also tried to adjust the tps following the bgb without success.
Please help i'm running out of ideas
