Finally I bought another, but also with probem. Here I present, although the photos are not of great quality
The day fuy to see ...
Sharing a room with his brother the small ...
The car has 240,000 KM, regarding interior plastic is pretty good ... the chairs must be repaired, although the front I would like to mount a pair of semi-bakets.
You should change head gasket, according to her former owner and his mechanic old
We must repair the steering pump from time to time need to replenish ATF
Tires the truth is that I do not like anything but the least
For now I want to make about 1,000 KM to see that oil consumption has not had much if only repair the butt, but I would redo engine "forge" and get a good basis although much is never potentiate
I would like to make some changes, but the fact is that I'm a bit lost as to what to give. I would like the car hit me a little more torque to seat?
My intentions are ...
Wheels with good tires semi slick. Tires still not measure by model and ... well you get the Mo6 but "I really view" and also oz
Good suspension
Within brakes not yet but I would not improve anything if the same measure or "swap"
full paint (so do not get me wrong engine comes and take advantage ...)
It depends what you can do something shorter Box, self-locking ... or leave as is
Question motor blow up or turbo intercooler and watercooler more ... I do not know, not if it will compensate ride some "exchange" an escape / line collectors ... that a good sound turbo
