If you want Cool, or Bling, get a kit.
The sky is the limit for Expense, or extra cheap ends from an audio
store for a ghetto set up.
You Can get some wire from an audio store, jumper cables
or welding supply, JWhitney etc and just make your own.
Red +, black -, easy. I use gold battery clamps for +
and silver for -, just for a bit of show.
IMHO, most improvement comes from cleaing the
grounding point of rust, dirt, grime etc...
A bigger wire May help if you are running a mondo
stereo of a high power ignition system.
I use 4 gauge for engine and alt. grounds and alt-battery+
Nothing like an afternoon with some some wire and a crimper....
Of course there Have been articles in magazines that
have Dyno results 'Proving' increased Hp with ground kits.
If you beleive Everything you read in magazines ?
(Not attacking Anyone. Just, there Have been Several
people hawking "Ground kits" on Several boards
promising the world of benefits... )
Regards;
