I tested my st165 for the first time at a dragstrip just to get a time on the car.
I had raced it it before with a G-tech meter in it and acording to that the car would do 13.99sec on the quarter. Much to slow I thougt but decided to go to the dragstrip anyway.
On the strip it turned out to go 13.37 sec and 160km/h
Not bad with stock ecu and injectors.
Next time on the trac will be on the 3 (julie) I will try to run a high 12sec.
The plan is to light it up a bit and switch to smaller wheels and add some more boost.
The mods on my car is:
Fmic,Eagle rods,JE pistons,TRD clutch, ported head,intake,exhust,cnc made 3"downpipe, little bigger turbo ct26, 3"exhust system, 17psi boost.
The rest is stock.
Its a picture of the car at www.402m.se
The rest is stock.
