where is the Speed signal wire in a 165?
Shaggz00
What color is the speed signal wire in my 165? and where is the best place to tap into it? I'm installing my Greddy turbo timer.
Rick89GTS
Dunno the best place to tap into yet - still haven't wired in my Blitz Multi Speed Turbo Timer but the Speed Sensor wire is Blue with White stripe coming out of the ECU, going into the combination meter. Coming out of the meter it is Black with Red stripe, going to ground.
Shaggz00
Thanks man! you gotta see the install I did for this timer.. I think its pretty cool. I just need to wire it up. I'll post a pic as soon as its done(tonight) :D
Rick89GTS
This is diagram is from the HKS manual. Diagram is shown from the wire side of harness (the "S" is the Speed Sensor Signal):
