Charcoal Canister Removal Write Up
Postby toayoztan » Sat Aug 19, 2006 8:48 am
Length of Time for this mod - ~ 30 minutes
Difficulty to perform this mod - Easy
What is the charcoal canister? To my understanding, it routes fuel vapor from the fuel tank back into the engine using this device. The device draws in fresh air, and "mixes" it with the fuel vapor. Then, there's a VSV on the water neck that basically controls on letting the "mixed air" into the throttle body. Basically, this is an emissions device. There's also claims of emissions device to help the engine run cooler, etc, but i'm not here to tell you that. Find out about what you want and need to find out about how/why this device is here before you decide to remove this. I did this because it makes more room, and there are no emissions here in my state of Oklahoma.
Alright, here's a quick and simple write up on how to remove your charcoal canister. There are other ways to do this, but this is how I did it. My disclaimer is that if something goes wrong as a result of what I told you to do, I am now therefore stating I do not claim this method to be 100% accidentproof/proper/etc (you get idea). So, don't blame me :wink: .
So, now, on to the writeup!
First off, you'll need to remove a few things. Assuming your car is stock, remove the intake box. This means to remove the afm with the air box lid AND removing the bottom portion of the air box by unbolting it. This just gives you more room to work with. Don't be lazy, it's only 2-4 bolts (depending on how many you're missing).
Second, remove your cruise control device for those that still have it. All you need to do it unplug it, and take off the two mounting bolts on the STRUT TOWER, not the bolts holding the mount bracket to the cruist control device itself. Then, just leave the cable and vac line on, and set the this thing out of the way as it permits you to do so.
Third, d/c the HT lead wire going from the coil to the distributor. It makes a little more comfortable room and it's only two clips. Again, don't be lazy!
Now, you should be able to see the charcoal canister. It will be sitting in the engine bay like this (this picture has the intake and what not still in). This picture is just to show the location of the charcoal canister after you remove everything:
You should see two lines going into the top of the canister. Disconnect both of these right now. Go ahead and remove the vac line from the VSV of the water neck too. Leave the VSV on the waterneck (you can remove this on your own other time, i won't discuss that here). There will be another vac line going from this VSV to the TB. It will be interwined with a lot of other hoses, so put some effort into this part and remove it. Then, be sure to get a vacuum cap to plug up the TB, so you don't have a vac leak. The fuel line, just set it aside for now. (NOTE: On JDM engines, I believe there is no VSV for the charcoal canister. Usually, the vac line goes straight to the TB from the charcoal canister.)
To get the canister off, you will need to remove two bolts. One bolt can be easily reached with a wrench (10mm I believe). The other bolt will require a ratchet, a long long extension, and a 10mm socket. Basically, find a suitable pathway between the brake master cylinder and strut tower to stick the extension/socket onto the bolt, and have at it.
After getting those two bolts off, don't just yank the crap out of the canister to get it out of the engine bay. Carefull rotate the canister so you can see the fresh air line connected to the bottom of the canister. Get whatever tool you need (screwdriver to pry, and pliers for the hose clamp) to get that fresh air line off. Then go ahead and remove the canister from the engine bay. Here's a pic of the canister showing the bolt hole locations and how the fresh air hose connects to the canister:
Okay, here's two more pictures examining what you should be seeing. Go ahead and just read the comments on the pictures, as it's easier to visualize with a picture in front of you!
Image Image
Alright, now that everything is identified, it's easy from here. Just take the fuel vap line and connect it to the fresh air line. That basically redirects the fuel vapors to just release into the atmosphere. It vents pretty much away from the engine bay to cause any damage to anything. Here's another pic to show you what things should be looking like:
Finally, go ahead and put the cruise control back on. And then put the intake air box all back on. DON'T forget to plug that AFM plug AND distributor wire back in, or you'll be wondering what you did wrong and possibly accuse the removal of the charcoal canister to be the culprit! Also, before putting everything back together, NOW would be a good time to change out that fuel filter hiding way down there.
I hope this helps in explaining what needs to be done. Any comments or suggestions, do say!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby omgitsroy326 » Sat Aug 19, 2006 9:00 am
nice write up , but did you notice a performance difference?
does a typical smog inspection look for this ?
omgitsroy326
Postby toayoztan » Sat Aug 19, 2006 9:05 am
omgitsroy326 wrote:nice write up , but did you notice a performance difference?
Thanks!
I didn't notice any performance difference. In fact, it's been said emissions actually help reduce engine temp or something to that extent. I know running w/o ANY emission device on my car currently, my temps are good. And remember, the other reason I removed this was to have less clutter. Since I removed my cruise control, it helps with me a lot.
As for what inspection looks for, I wouldn't know. But i can tell you, they wouldn't really be able to see this thing with the cruise control and everythigne else there. Hopefully someone will chime in!
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby syko says » Sat Aug 19, 2006 9:26 am
alright! thanks bryan. i plan to do some removals this later weekend. EGR and charcoal canister; bye bye :) . not planning to drive my car anywhere soon anyway. thanks again and you are the write up master :notworthy:
Aloha,
Evan
syko says
Postby Fraggle » Sat Aug 19, 2006 9:56 am
i think gary did this mod a while back, maybe he can give some input as to how it affects the vehicle overall
92 alltrac. 3" exhaust, intake, hks ssq bov, mbc @ 11 psi, TRD 3 puck clutch and XTD lightweight flywheel.
::::Vroooooom PSSssshhhh rattle rattle clunk clunk snap::::
Fraggle
Postby toayoztan » Sat Aug 19, 2006 10:02 am
Haha thanks sykosays.
Yeah, I got the idea from Gary. I just had some time to kill and decided to do a quick write up on it.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby Gary » Sat Aug 19, 2006 3:21 pm
Nice write up. Someone should sticky this.
There is no known effect.
I did not notice any smell.
The only two benefits are weight reduction and more space in the engine bay.
93 ST185
Gary
Postby toayoztan » Sat Aug 19, 2006 7:01 pm
Gary wrote:Nice write up. Someone should sticky this.
Thanks Gary, but :doh: I should have wrote this in the FAQ section to become a sticky. Would a moderator please move this over there :D
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby CMS-GT4 » Sat Aug 19, 2006 7:32 pm
Thanks for the writeup. I will be attempting this in the next couple of days.
Postby 1BADGT4 » Sun Aug 20, 2006 12:08 am
Living in CA, and that the charcoal can is an emissions part, I would definitly(sp?) leave it on.
UT2 (SCW) Chan - Oakland, CA
04 Duc Monster DS
400BHP @ 20#, low 12s
1BADGT4
Postby tw2 » Sun Aug 20, 2006 7:47 am
I noticed absolutely no difference except a nice space to put my catch can in. It did smell of petrol vapour for a few hours since thats what the lines contained. I was sceptical of venting the vapour into the fender well but have had no problems with it at all and no smell to speak of.
Thomas, JDM 90 185, 06 350z
tw2
Postby Denver_whiteST185 » Sun Aug 20, 2006 7:59 am
quick question brian, whats a VSV.
would any autoparts store have vacum caps, or should i get these somewhere off the net? im going to need two cause one is for my intake pipe cause i don't have a BOV to route in there yet.
^Ted^
Denver_whiteST185
Postby tw2 » Sun Aug 20, 2006 8:02 am
Any auto parts store should have them in many different sizes. Most turbo vacuum lines / intake lines are 6mm with the small vacuum lines being around 4mm. Is the VSV (variable switching valve) the small cream/yellow thing with a tube going onto each end? the jdm engines do have these.
tw2
Postby toayoztan » Sun Aug 20, 2006 9:42 am
I believe vsv means vacuum switching valve.
I didn't know if the JDM had this or not. On my friends JDM 3sgte, he didn't have it. And I don't know if it's yellow or not, as what mine shows in this pic is very dirty, with a blue tip heh. This is where the VSV is by the way:
(at red arrow)
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby theUNYTEDone » Sun Aug 20, 2006 10:37 am
this is great. amen to the person who said this would be a nice place for a catch can.
i'll be doing this after my car's running fine and well again (and it's well on the way to that, thanks to keoni)
few more days...
damn the fact that school's starting up for me. bleah.
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Return to FAQ / Archive
