do MR2's have the same tie rod ends?
Postby Denver_whiteST185 » Wed Mar 07, 2007 8:36 am
i found this for MR2's and i was wondering if it would fit an alltrac?
you cant read the info on it unless you sign up, but it says:
"You are viewing Brand New Set of 'Pillow Ball Tie Rod Ends' designed specifically for the SW20 MR2 by the highly respected MR2 Specialist company, Phoenix Power. When you lower your car you change the suspension geometry (toe) of your SW20 and the items are highly recommended on any lowered SW20."
https://www.rhdjapan.com/home/products/ ... t_id=2408#
Last edited by Denver_whiteST185 on Wed Mar 07, 2007 3:30 pm, edited 1 time in total.
^Ted^
Denver_whiteST185
Postby Denver_whiteST185 » Wed Mar 07, 2007 3:27 pm
bump for CMS-GT4, Griffin, or one of the other OG's.....
^Ted^
Denver_whiteST185
Postby gtfour77 » Wed Mar 07, 2007 6:04 pm
I believe this would work... This would be a great way to eliminate bump steer! Excellent find....do you know the price by any chance?
Martin V.
Toyota Celica Alltrac 561 SM
Toyota MR2 Turbo 35 SSM
gtfour77
Postby Denver_whiteST185 » Wed Mar 07, 2007 6:51 pm
$353.78 + shipping :shoots:
they are expensive, but they look nice.
^Ted^
Denver_whiteST185
Postby gtfour77 » Wed Mar 07, 2007 6:55 pm
Ouch, that's wayyyy too expensive for what it really is... Time to call pegasus racing...
Martin V.
gtfour77
Postby Denver_whiteST185 » Wed Mar 07, 2007 7:03 pm
gtfour77 wrote:Time to call pegasus racing...
elaborate please?
^Ted^
Denver_whiteST185
Postby gtfour77 » Wed Mar 07, 2007 7:07 pm
Pegasus racing has tons of different ball joints, spherical bearings, tie rod ends etc. for all sorts of race cars...
Go to www.pegasusautoracing.com and you'll know what I mean. I am not 100% sure they'll have everything you need but they are the guys I got all my brake lines and adaptors for my wilwoods from. They also know car stuff....;) Have them send you a catalog...
Martin V.
gtfour77
Postby Denver_whiteST185 » Wed Mar 07, 2007 7:12 pm
cool will do.
As for those phenoix power ones, i think when i stop by the toyota dealership today, im going to see if MR2's have the same part number as ours.
These also came up. im not sure i even know what they're for, but they want $ 378.38 + shipping for them :shock:
https://www.rhdjapan.com/home/products/ ... t_id=2233#
You are viewing Brand New Set of 'Roll Center Adapters' designed specifically for the SW20 MR2 by the highly respected MR2 Specialist company, Phoenix Power.These are a must on any lowered SW20. When you lower your car you change the suspension geometry of your car. These will correct your roll center and allow you to have the original steering feel while having your car lowered.
^Ted^
Denver_whiteST185
Postby db » Wed Mar 07, 2007 10:24 pm
Sounds like they correct "bump" steer. As long as your aren't slammed to the ground, I don't think you'll need something like that.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby Trance4c » Wed Mar 07, 2007 10:54 pm
gtfour77 wrote:Pegasus racing has tons of different ball joints, spherical bearings, tie rod ends etc. for all sorts of race cars...
I wish someone could have a spherical bearing that would fit the rear control arms of an ST184!
Trance4c
Postby gtfour77 » Wed Mar 07, 2007 11:36 pm
db wrote:Sounds like they correct "bump" steer. As long as your aren't slammed to the ground, I don't think you'll need something like that.
Certainly wouln't be as beneficial as a roll center adjustment shim...very think shim (1.5 inches maybe..) Hopefully I can make one soon...
Martin V.
gtfour77
Postby CMS-GT4 » Thu Apr 05, 2007 5:48 pm
I just saw this. Keep us posted if anyone finds an affrodable set. I have always found our stock tierod ends to be a weak point in our cars.
Postby Denver_whiteST185 » Fri Apr 06, 2007 4:40 am
CMS-GT4 wrote:I just saw this. Keep us posted if anyone finds an affrodable set. I have always found our stock tierod ends to be a weak point in our cars.
Well, those ones defiantly aren't "affordable" in comparison to other options (since just getting new stock ones are around $50 IIRC) plus they don't look the same as stock tie rod ends.
i actually got a worn tie rod end off a local parts car (since the steering rack was bent very badly and was about to be tossed) and i would like to take some measurements, call up the site that gtfour77 recommended, and see if they have something that they could put together for me. But thats on a long list of things that will take a little while to get done. ill make a new thread if some major progress goes through (especially since my tie rod ends are pretty worn)
^Ted^
Denver_whiteST185
Postby 3sgte@daspeedof » Fri Apr 06, 2007 11:33 pm
Alltrac hood, carcept sides, erubuni front lip
3sgte swapped celi
A boosted Celica is fun, Seeing the look on someones face when they get left by a car that is primered is priceless
3sgte@daspeedof
Postby Denver_whiteST185 » Sat Apr 07, 2007 12:14 am
Tie rod ends are diferent than endlinks
^Ted^
Denver_whiteST185
