ST205 Front Brakes
ST205 Front Brakes
Postby SuperWhite92 » Tue Mar 27, 2007 4:28 pm
Do not clear 7th Gen Celica rims.
Not even close. To fit they'd need to have an extra 1/2" of spoke clearance around the caliper, and to have more room around the outside of the rim. Yes, you read that right, they hit both the spokes and the rim at the same time.
SSR Comps however, will work. There's about 1mm clearance on the center-most part of the spokes, but there's room everywhere else.
Shaun
SuperWhite92
Postby Denver_whiteST185 » Tue Mar 27, 2007 4:32 pm
sweet 8)
^Ted^
Denver_whiteST185
Postby etantshi » Tue Mar 27, 2007 6:03 pm
Nice to know. So a spacer would not work. Might be time to sell my GTS wheels.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby lumbercis » Mon Apr 09, 2007 1:00 am
Did you make your own braket to mount the fronts? Any pics? Wouldn't mind seeing your SSR comps either. :smokes:
J.
lumbercis
Postby Denver_whiteST185 » Mon Apr 09, 2007 3:02 am
i will be getting brackets made so that they will fit with the entire brake rotor instead of milling the brake rotor down to ~297mm. however they are not made yet.
My SSR comps 8)
^Ted^
Denver_whiteST185
Postby b00staholic » Mon Apr 09, 2007 6:22 am
The diameter, width, and offset of the SSR Comps that this applies to would be useful.
Vincent
'90 ST185
b00staholic
Postby Denver_whiteST185 » Mon Apr 09, 2007 6:26 am
^Ted^
Denver_whiteST185
Postby SuperWhite92 » Mon Apr 09, 2007 6:46 am
Just a side note- any higher an offset or any less spoke curvature (which may be affected by width) and the brakes WILL NOT CLEAR. Words can't describe the size of the calipers effectively.
Shaun
SuperWhite92
Postby SuperWhite92 » Tue Apr 10, 2007 4:38 am
Another note- SSR Comps in this size will clear Subaru 4 Pot brakes with appalling amounts of room to spare. Unfortunately, on the GC we tested it on, it's a few inches out the fender.
Shaun
SuperWhite92
Postby eddie_gt4 » Thu Apr 19, 2007 11:49 am
Denver_whiteST185 wrote:i will be getting brackets made so that they will fit with the entire brake rotor (...)
smth like this? :)
as you can see, these brackets need to be slightly machined :wink:
p.s. putting ST205's F and R rotors and calipers into ST185 requires putting bigger master brake cylinder?
or an OEM one is efficient enough?
'90 Toyota Celica turbo 4WD ST185 - ex
'96 Toyota Celica GT-Four ST205 - now
eddie_gt4
Images: 11
Postby Denver_whiteST185 » Thu Apr 19, 2007 4:26 pm
Oooo who makes that and are there more for sale?
The stock 185 master cylinder is fine and is actually slightly larger than the stock 205 one
^Ted^
Denver_whiteST185
Postby sleeper » Thu Apr 19, 2007 7:23 pm
does anyone make those brackes for sale?
someone should make brackets and spacers for sale! ( i would buy some if the price wasen`t insanly high...)
sleeper
Postby GT4RC » Thu Apr 19, 2007 7:35 pm
yet another mod i want done for this summer. is that setup intended to be used with 185 or 205 rotors?
GT4RC
Postby Denver_whiteST185 » Thu Apr 19, 2007 8:46 pm
GT4RC wrote:yet another mod i want done for this summer. is that setup intended to be used with 185 or 205 rotors?
You cant use 185 rotors with 205 calipers.
^Ted^
Denver_whiteST185
Postby eddie_gt4 » Fri Apr 20, 2007 5:29 am
Denver_whiteST185 wrote:Oooo who makes that and are there more for sale?
I don't know who's making it, but such brackets arrive from time to time on Japan Yahoo auctions
actually they're designed fot the Caldinas (that afaik have the similar setup as a ST185)
btw, thanks for the info about the master cylinder :wink:
eddie_gt4
Images: 11
