1991 GT4 RC - 03/26/10 -BAD NEWS :( Probably gonna sell
Postby edmonton_oiler16 » Wed Nov 26, 2008 6:11 am
Car Before
Took approximately 20 hours + or - a couple hours
Worn Clutch, the reason of all this work
Last edited by edmonton_oiler16 on Fri Mar 26, 2010 8:01 pm, edited 30 times in total.
1991 Celica GT-FOUR RC
St. Paul, Alberta, Canada
Project: http://alltrac.net/phpBB2/viewtopic.php?t=30790
edmonton_oiler16
Postby mx6er2587 » Wed Nov 26, 2008 12:03 pm
are those casters bolted onto the cross members? thats an awesome idea.
My only question is how did you get the car up high enough to get the engine out from underneath? Looks like the front would need to be more then 2 1/2 feet up?
This will be my project in the spring except I'll be replacing the entire tranny instead of the clutch.
nice work and its interesting to see the time frame on it
mx6er2587
Postby LegacyofDan » Wed Nov 26, 2008 12:28 pm
i second that /\, good post, i saw this when u first posted ur first pics, and thought to myself well this should be promising, good job :)....and my god ur clutch looks like shit...haha dont worry so did mine :P
I <3 165's
Postby Terracar » Wed Nov 26, 2008 3:09 pm
wow looks like down to the rivets on the clutch plate and looks like so serious gouging on the pressure plate - what clutch you planning on replacing it with?
-Terracar
Terracar
Postby edmonton_oiler16 » Wed Nov 26, 2008 3:56 pm
no the car only had to be lifted a little to remove the engine. and I have a Exedy Stage 1 Clutch ready to be put in. Probably gonna replace alot of the little stuff to.
edmonton_oiler16
Postby Corey Darling » Wed Nov 26, 2008 6:09 pm
I think he wants to know exactly how the car was lifted to get the motor out. The usual method is to hoist the car from the bumper bar, but the cover is still on :shrug:
Corey Darling
Images: 50
Postby MrDB » Wed Nov 26, 2008 8:39 pm
Put left and right engine mount bolts in and an use those to lift...
Awesome idea for use of casters will be using that idea when i next drop an engine out. Top stuff....
MrDB
Postby Landon » Thu Nov 27, 2008 1:19 am
are you going with your original intercooler? as in putting the same one back on. Just out of curiosity.
Landon
Postby Gary ST165 » Thu Nov 27, 2008 1:21 am
your RC looks in good shape. 8)
keep it that way and put some masking tape / latex gloves over the throttle body inlet & turbo inlet & turbo oulet, transfer case etc to avoid debris! :doh:
ST165 turbo 4WD
Gary ST165
Postby Rick89GTS » Thu Nov 27, 2008 2:14 am
mx6er2587 wrote:are those casters bolted onto the cross members? thats an awesome idea.....
+1 :D
Rick89GTS
Postby Autobot » Thu Nov 27, 2008 3:30 am
So far so good.
Autobot
Postby Gary ST165 » Thu Nov 27, 2008 8:45 pm
be well aware of a common ST185 weakness: steering rack mounting cracks!
we have just taken the engine out of my RC to inspect the bottom end bearings (A1 condition) , clutch (plenty of life left), hoses from hell, new water pump ......and sort out the steering rack.
the underseal requires scraping back and then welding & reinforcing >> when the steering wheel is wiggled you can see as it has flex and cracks open up on the bulkhead :shock:
please view the attachmnets, hope that helps
ST165 turbo 4WD
Gary ST165
Postby Corey Darling » Thu Nov 27, 2008 9:05 pm
Holy crap, i've never heard of this issue before?
Corey Darling
Images: 50
Postby edmonton_oiler16 » Thu Nov 27, 2008 11:17 pm
yes i am just putting the original intercooler back on. And to lift the car to remove the motor just used jacks seen in the picture.
edmonton_oiler16
Postby Speed Stick » Sun Nov 30, 2008 12:21 am
I told you the clutch was bad lol. Is actually worse then I imagined.
Sean
1993 JDM Subaru WRX (Daily Driver and tuned via ESL. 218whp and 215wtq)
2000 Honda Prelude (SOLD)
1991 GT-FOUR RC (SOLD)
Speed Stick
