alltrac.net gtfour.net
Celica All Trac
It is currently Thu Jul 29, 2010 10:44 am
Post new topic Reply to topic  [ 279 posts ]  Go to page 1, 2, 3, 4, 5 ... 19  Next
Author Message
 Post subject: [Toyota Part Numbers]
PostPosted: Sun Aug 08, 2004 4:25 pm
Offline
Site Admin
Post common part numbers we need to know about. Your post will be deleted once the part numbers are added to the complete list.
Top
 Profile E-mail
 Post subject:
PostPosted: Mon Aug 09, 2004 12:47 am
Offline
oil cooler water line gasket - 16258-88383
gasket, joint for turbo oil pipe - 15526-88381
Hose from Hell #1 - 16283-88381
#2 - 16282-88380
Exhaust manifold gaskets - 17173-88381
Turbo oil line gasket - 15471-88580
For oil cooler I have
15517-88380
96732-19019
90301-52002
15785-35010
15471-88580
_________________
1990 ST185 sold
West Hartford, CT
Top
 Profile E-mail
 Post subject:
PostPosted: Mon Aug 09, 2004 4:06 am
Offline
RC/CS Hood part numbers
Bonnet Panel (hood) 1 53301-20400
Guide #1 1 76182-20020
Guide #2 1 76191-20900
Retainer 2 76188-20010
Bulge (Scoop insert) 1 76181-20901
Plate 1 76192-20010
Cushion 1 76186-20010
Cushion 7 76183-12030
Retaining Nut 6 90179-05081
Retaining Nut 4 90179-05103
Hood Scoop Bolt 3 90164-50033
Retaining Washer 3 90183-06009
Scoop to hood bolt 8 90109-06241
Cushion 8 90540-06032
Retaining Nut 8 90179-06007
Ornament 033=LH, 034=RH 2 75033-20020-202 (Black)
_________________
93 ST185
Top
 Profile
 Post subject:
PostPosted: Mon Aug 09, 2004 4:07 am
Offline
RC/CS Bumper part numbers
Reinforcement #1 52021-20210
Reinforcement #2 52029-20010
Fascia 52119-20929
Grille LH 53104-20030
Grille RH 53103-20030
Grille Lower 53102-20030
Grille Center 53101-20450
_________________
93 ST185
Top
 Profile
 Post subject: Turbo intake hose
PostPosted: Wed Nov 03, 2004 7:14 pm
Offline
The first rubber intake hose that connects to the turbo.
(ST185)
#17882-74160 *Hose, A
_________________
Black 1992 St185 (98,XXX miles). Stock for now
Top
 Profile E-mail
 Post subject:
PostPosted: Tue Feb 08, 2005 3:19 pm
Offline
10/89-9/93
cam:90311-35040
crank:90080-31022
rear:90080-31073
_________________
88 St165
89 240sx
91 240sx conv.
Top
 Profile
 Post subject:
PostPosted: Tue Feb 08, 2005 7:23 pm
Offline
Also oil filter changed numbers, they are made in the phillipines and not the good ol us of a:
st165 old=08922-02011 new=90915-YZZD1
st185 old=90915-YZZA1 new=90915-YZZE2
fuel filters
st165=23300-79105
st185=23300-19225
air filters
st165+185=17801-74020-83
_________________
88 St165
89 240sx
91 240sx conv.
Top
 Profile
 Post subject:
PostPosted: Wed Feb 16, 2005 10:16 pm
Offline
I've copied all these part numbers down to the TracFAQ. If anyone has more part numbers to add, you should add them to the TracFAQ.
TracFAQ Part Numbers List
_________________
Top
 Profile
 Post subject:
PostPosted: Thu Feb 17, 2005 6:39 pm
Offline
I think that rc bumper reinforcement number two is the wrong number. It shows up as a regular celica upper bumper support.
_________________
2005 WRX STi
Top
 Profile E-mail
 Post subject:
PostPosted: Thu Feb 17, 2005 6:46 pm
Offline
Or is it because they are the same part? :shrug:
_________________
93 ST185
Top
 Profile
 Post subject:
PostPosted: Thu Feb 17, 2005 11:43 pm
Offline
If you use the stock reinfocement the top of the bumper hangs down to low and looks like butt. If i remember on the old board someone had the true part number.
_________________
2005 WRX STi
Top
 Profile E-mail
 Post subject:
PostPosted: Tue Mar 01, 2005 12:28 am
Offline
gas tank related
filler neck-77201-20420
gasket ^ - 77169-14010
evap line- 77018-20130
gasket ^ -77179-16010
valve cover gasket -11214-88381 inner
-11213-88381 outer
engine gasket set-0411174170
_________________
Austen-albany/utica ny
09-m109r LE
04 IS300
91-MR2T-for sale
Top
 Profile E-mail
 Post subject:
PostPosted: Tue Mar 01, 2005 3:20 am
Offline
All added to TracFAQ :)
Keep the part numbers coming, people. Preferably adding them to TracFAQ yourselves. ;-)
_________________
Top
 Profile
 Post subject:
PostPosted: Tue Mar 01, 2005 3:27 am
Offline
wrong Reinforcement #2, part number: 52029-20010. This part is identical to the one that is already on your car. I have no idea why they even have it listed.
The actual part you need is 52029-20020
_________________
Dustin, Baker Curb Racing Fabricator
1990 All Trac w/ RC bumper, converted to 93 spec
1979 Malibu (just a little SB chevy ;)
1995 Dodge Ram 1500 (work truckage)
Benton, KY
Top
 Profile E-mail
 Post subject:
PostPosted: Tue Mar 01, 2005 11:57 pm
Offline
ok here are the brake/ gas lines from front to back (185)
tube to fuel tank 77261-20330
tube fuel return 77255-20540
tube fuel main 77251-20670
tube rr brake #1, 47321-20320
tube rr brake #2, 47322-20450
_________________
09-m109r LE
04 IS300
91-MR2T-for sale
Top
 Profile E-mail
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
