hi
hi
Postby brian008 » Mon Apr 09, 2012 10:20 am
hi all, i have been looking at this site since i got my 1990 gt four in gun metal grey (jap import) and im the second owner of it.
I hunted for a while for the right car as i tend to hold on to them for years ( i had a classic mini for 11 years )
I got alot of history with the car so i know it was a good buy,
some of the bits changed
JE Forge Pistons
Upgraded Actuator
Stage 1 Turbo, Larger Compressor wheel
GT4 Eibach spring kit
Apexi Turbo Timer
Head Fully Rebuilt with genuine parts
Boost controller
and loads more.......
Car is not on the Road at the moment as i developed an leaky turbo so i have sent it in to get serviced. but cant wait to get it back. I will post some pics soon
thanks
brian008
Re: hi
Postby brian008 » Fri Apr 13, 2012 5:43 pm
hi again, just a quick question. will i be able to get 400 bhp out of my gt? is so what will i have to do to achieve 400bhp????? :D
brian008
Re: hi
Postby UtahSleeper » Fri Apr 13, 2012 6:38 pm
Welcome aboard. Pics or build thread would be good :)
Not sure on the 400 mark. If I recall correctly I thought 300 or 350 was the limit of the stock fuel system. Plus I assume a standalone would be needed to get that much.............anything is possible though.
80 Corolla Hatchback - Power (In Progress) http://www.3tcgarage.com/viewtopic.php?f=23&t=3208
88 Alltrac - Snow (Waiting for the garage) http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=43482
Cardomain - http://www.cardomain.com/id/chris52580
UtahSleeper
Re: hi
Postby brian008 » Sat Apr 14, 2012 3:11 am
I have ordered an upgraded fuel pump as i read on here about the fuel cut off so i will start with that.
any other ideas will help thanks
brian008
Re: hi
Postby brian008 » Sat Apr 14, 2012 4:45 pm
ok i have done some research and i have seen a problem starting with the ecu and the fuel cut off, but with a bit of looking around i for this "fuel cut defender" http://www.k1ano.co.uk/index.html for only £15 to sort that out. just thought id put it here just to let you all know :D
brian008
Re: hi
Postby UtahSleeper » Sat Apr 14, 2012 4:47 pm
Yea, that will help with trying to get power. There are a few people here familiar with hitting 400+. Hope they say something or you find some of their threads :)
UtahSleeper
Re: hi
Postby RoAdbOy » Tue Apr 17, 2012 8:54 am
hi there :) welcome...
iirc you don't need a FCD, you can just disconect the turbo pressure gauge vacuum hose and fixed the cut off :D but i would still recommend to buy a FCD, because it's boring without a unfunctionally pressure gauge :)
[IMG]http://i.imgur.com/emTLn.jpg[/IMG]
Mehmet Ali Ovacikli
istanbul / TURKEY
zürich / SWİTZERLAND
RoAdbOy
Re: hi
Postby brian008 » Tue Apr 17, 2012 4:16 pm
thanks but i have put in an order for the FCD and its in the post. i also ordered a performance chip for the celica. i have also ordered an upgraded manual boost valve. so ill fit them all when they get here and see how we get on with that.
thanks for all the posts by the way
brian008
Re: hi
Postby lele73 » Mon Apr 30, 2012 4:31 am
I likey!
1 3 5
2 4 6 R
Image HDM
lele73
Re: hi
Postby 4rsnduction » Mon Apr 30, 2012 8:13 am
brian008 wrote:hi again, just a quick question. will i be able to get 400 bhp out of my gt? is so what will i have to do to achieve 400bhp????? :D
Stock fuel system wouldn't make it past 300whp
The problem is the entire system, pump dosnt flow enough, fuel rail is side feed and internal diameter is too small for flow, likewise the injectors are too small for decent flow...
If you looking for 400whp then 800cc or larger injectors would be recommended aswel as a new top feed fuel rail and 255L or greater fuel pump........not to mention the standalone ecu to control it all.
Some form of cams will be needed as the stock duration and lift are pathetic compared to WRX and EVO rivals.
The turbo will eventually run out of puff, if you can get 400whp from the stock turbo i'll be really proud of you.....err.....your tuner :P
RoAdbOy wrote:hi there :) welcome...
I do exactly this......i dont want to cut anything to install a FCD and i'll be getting a wolf v500 ecu soon to counter the problem
4rsnduction
Re: hi
Postby brian008 » Wed Jul 04, 2012 6:22 pm
lol thanks for that mate informative yet funny :D , i went and bought a FCD but when i was fitting it there was a better one already fitted, 8) . as for the infectors i found 650 ones on ebay for £160 so they will have to do for now. i might have a think about upgrading the turbo to a 60mm trim and see how i get on with that.
thanks
Brian
brian008
Re: hi
Postby CelicaAlltracHKS » Fri Jul 06, 2012 5:41 pm
ver nice my friend!
CelicaAlltracHKS
Re: hi
Postby brian008 » Wed Jul 25, 2012 2:54 pm
CelicaAlltracHKS wrote:ver nice my friend!
brian008
Return to New Member Forum
Users browsing this forum: Google [Bot] and 0 guests
