Any lightweight pulleys out there?
• Page 1 of 2 • 1, 2
Wondering what kin of lightweight pulleys are out there for us. Found a crank pulley for 95. That mainly the only one to change right?
91 Celica Alltrac - Parts pile pending instal
3SGTE project motor very slow
celigts - Established Member
Re: Any lightweight pulleys out there?
Search around under an MR2 and you will find them
Hotrodhendrix - GTFour God
DO NOT use a lightweight crank pulley!!!! Our engines are equipped with a harmonic dampener not just a pulley. If you remove it and put a piece of aluminum on without the rubber insulation built into the pulley it will cause excessive harmonics inside the engine. This WILL cause premature engine failure. If you want to reduce weight run a chromoly or aluminum flywheel. If you want to replace the dampener just purchase a new factory one from Toyota.
Allen
Allen
Allen
1990 Volvo 760 Turbo "Go fast for Less" Daily
1992 Toyota Celica Alltrac "Go nowhere for More" Project
2012 Lexus ES350 "Kid Taxi" Wifes Daily
- ALLensTRAC
There are usually underdriven alternator & powersteering pullies as well. Personally I'd never mess with the crank pully and just change the alt & ps, and a lightened flywheel.
1987 GT-S -> rust in piece
1991 RC -> project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=44216 "Darlinda the Tie Fighter"
1992 GT-S -> daily
2000 Cherokee -> ski hauler
1997 Prelude -> girlfriends daily/project "Charmeleon"
1992 GT-S -> daily
Damn it's a good thing I didn't go forward with buying one. Are there none out there with the harmonic balancer in it as well?
Currently have no ps so that won't matter lol but seems like pretty useless going this route.
Yeah, would never get a crank one. I never notice a difference on the air flow metered cars, the speed densitycars are much more noticeable.
-jr
-jr
feb. 1990 alltrac red one: fun machine http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27076#p253730
feb. 1990 alltrac blk one:dd
5x114.3 write up:
http://www.alltrac.net/phpBB2/viewtopic.php?f=20&t=43769&p=411470#p411467
5x114.3 write up:
tubasteve - Established Member
How about if we had the stand alone. Would we see the difference having lighter pulleys?
Did anyone notice a difference when or if they removed the ac and swapped belts and changed the tensioner pulley with grooves. I don't think there would be but still floating as a question
I ditched my AC but then blew my turbo haha, chances are you won't fel the difference, but it will be easier on the engine to ditch the AC, running or not.
1992 GT-S -> daily
1992 GT-S -> daily
celigts wrote:How about if we had the stand alone. Would we see the difference having lighter pulleys?
The stand alone s are mostly speed density.
5x114.3 write up:
5x114.3 write up:
underscore wrote:I ditched my AC but then blew my turbo haha, chances are you won't fel the difference, but it will be easier on the engine to ditch the AC, running or not.
Way ahead of you
why is it easier on the engine? less heat or something?
- Refyused
Invest in a lightweight drive shaft and a lightened flywheel....
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC - Club Member
Refyused wrote:underscore wrote:I ditched my AC but then blew my turbo haha, chances are you won't fel the difference, but it will be easier on the engine to ditch the AC, running or not.
less resistance. even without the pump running, having that extra pulley on there saps power.
1992 GT-S -> daily
1992 GT-S -> daily
I gotta get rid of that compressor yet.
unless you are moving to the ATI fluid dampener which is about 2 lbs lighter than stock for 3 times the cost, then leave your pulleys alone.
Built Gen 1 3SGTE,Megan,Autopower,Forza,Precision,Haltech,COP,Racepak,FMIC,Nitto,CRW axles,Quaife,V6 trans,Competition Clutch,Fidanza,Moroso,ST,370whp,340tq
Sponsors: Midas, SRT, Paradise Racing, CRW, ST162.net
Mafix - Gold Member
