Benefits you've noticed from Cam gears
General Chat
Postby celigts » Fri May 04, 2012 11:35 am
I know there are lots of cam gears out there from solid to adjustable and what I'm wondering is what you guys have felt has a difference.
Will weight make a large difference, will adjustability matter with stock cams and ecu,?
3SGTE project motor very slow
celigts
Re: Benefits you've noticed from Cam gears
Postby WarTowels » Fri May 04, 2012 1:23 pm
I can't speak from experience, but I really doubt you can "notice" cam gears. When going aftermarket their purpose is to allow adjustment. Also, in my case, and probably most cases cam gears come along with other mods and aren't a single upgrade so determining improvement based on feel would be really difficult. I wouldn't go in to a cam purchase looking to feel any difference what so ever. What you need them for is during the tuning process, you'll feel the improvements of a better running engine but not the gears themselves.
Correct me if I'm wrong...
-Towels
1993 All-trac
2003 S2000
WarTowels
Gold GTfour God
Postby tubasteve » Sat May 05, 2012 5:38 am
On 185 and older, doesn't the exhaust can being retarded 3° help turbo spool and more gain, i believe the 205 can has 2° retard stock.
Might be 7° helps, it's been so long. Honestly info I'd take with a grain of salt cause i won't adjust mine unless on a dyno.
-jr
feb. 1990 alltrac red one: fun machine http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27076#p253730
feb. 1990 alltrac blk one:dd
5x114.3 write up:
http://www.alltrac.net/phpBB2/viewtopic.php?f=20&t=43769&p=411470#p411467
tubasteve
Postby klue » Sat May 05, 2012 2:13 pm
you can go up to 6deg on the exhaust for gen 2, helps it breathe a bit better up top. but not a huge gain. I would only do it if your already in there changing a timing belt or something. Better up grade is the gen 3 cam, which has more duration, more lift, and is timed 4 degree over the gen 2
xiiimotorsports
st175
Postby celigts » Sat May 05, 2012 2:17 pm
klue wrote:you can go up to 6deg on the exhaust for gen 2, helps it breathe a bit better up top. but not a huge gain. I would only do it if your already in there changing a timing belt or something. Better up grade is the gen 3 cam, which has more duration, more lift, and is timed 4 degree over the gen 2
See this is where I don't understand.. Timings.
So if you say the gen3 cams are different by about 6' then what does it change. When the the plugs fire?
celigts
Postby tubasteve » Sat May 05, 2012 2:56 pm
The end of the exhaust stroke is held in a little longer for the degree of duration. It has nothing to do with spark as much (intake cam drives distributor). During this time had more push out into the exhaust for better turbo response. But with the gen 3 cams on gen 2 engine makes a world of difference.
Retard = late
Klue, i believe the gen 3 were less than that,i thought it was half of what you need, 3°? But i could be way wrong.
-jr
5x114.3 write up:
tubasteve
Postby celigts » Sat May 05, 2012 4:18 pm
So both cams actually have different strokes? Might sound stupid but I had no idea lol
Since cams are expensive would putting an adjustable cam gear do the same as switching cams ?
Is it easy to find the st205 exhaust side cam?
celigts
Postby OutToWinPAHC » Sat May 05, 2012 4:22 pm
I dont like to use the adjustable gears mainly because I have seen the adjustment screws work loose. Some see great benefits with using them, especially when using longer duration cams with very custom set ups where that one degree means the world. However I do have Tomei cam gears on my Nissan Skyline which came with the car and I am going to see how they do.
1990 ST185 All-Trac 54trim
1993 Nissan Skyline R33 GTS25T-M widebody built 60trim R34 NEO AEM-Series 2
OutToWinPAHC
Postby klue » Sun May 06, 2012 1:45 am
If you guys re read what I said, I was trying to say that you can go up to a max of 6deg on a gen2 cam with adj gears before you start to diminish the returns.
the gen 3 ex cam is retarted 4 deg more than the gen 2 so the power is near optimal. not to mention the added lift and duration. Its a wonderful cam, should have came in the gen2 to begin wiht
xiiimotorsports
st175
Postby tubasteve » Sun May 06, 2012 1:57 am
I was trying to half ass explain how it helps.
5x114.3 write up:
tubasteve
Postby darthripley » Mon May 07, 2012 12:45 am
if you only put on the cam gears & adjust the exhaust to be slightly retarded & the intake slightly advanced you'll pick up maybe 10hp at the flywheel.
unless you are putting in camshafts with more duration & higher lift then it's essentially a waste of time to put on just the gears considering what a pain they are to get to in the engine bay.
camshafts & gears aren't a "plop in" type of a mod. to get the most out of them you must spend time on a dyno fine tuning them in. along with them timing comes into play as well which is a huge discussion i don't want to even start up.
save your money & put it where you will feel it with dp, mp, exhaust & turbo upgrades.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby Hotrodhendrix » Tue May 08, 2012 4:07 pm
Mine are set at stock so about the only benefit is they are purple and match the timing belt.. :twisted:
Postby gearhead313 » Wed May 09, 2012 3:46 pm
I mostly have experience with cam gears on hondas, so here's my 2c. Stock cams are usually dialed in from the factory, very little gains can be seen from JUST cam gears.
Aftermarket cams on the otherhand can be dialed in to make sure you get the most out of your setup. Usually cams are centerlined and degreed, but some (most) 4cyl are difficult to do and the fixtures sometimes need custom made... big pain, so an hour or so of cam tuning on the dyno can allow you to find the sweet spot.
Here's a good example from Evan's on one of my fav motors, an H22A:
http://www.evans-tuning.com/dynos/wp-co ... bhatch.jpg
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - win (for now)
gearhead313
Postby Mafix » Wed May 09, 2012 6:56 pm
h22's almost need cam gears. we woke up my one friends n/a h22 with a set. night and day difference.
mine just look purdy. other than that...not a damn thing. yet.
371whp,355tq w/ 46mm restrictor plate
Sponsors: Redds Automotive, Swift Racing Technologies, Paradise Racing, CRW, ST162.net
Postby gearhead313 » Thu May 17, 2012 10:15 pm
weight savings? ...i nver weighed any
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Return to Club Chat
