Performance issue, pre boost
• Page 1 of 1
What could cause a motor to feel like its hitting fuel cut pre boost? When I get into boost its fine, but there is no power when trying to get there and as I open the throttle, it jerks my around almost as if I was hitting fuel cut.
If more info is needed, let me know. Just trying to get ideas for what to poke at. Plan on building a boost leak tester soon just to rule out air issues.
80 Corolla Hatchback - Power (In Progress) http://www.3tcgarage.com/viewtopic.php?f=23&t=3208
88 Alltrac - Snow (Waiting for the garage) http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=43482
Cardomain - http://www.cardomain.com/id/chris52580
UtahSleeper - Established Member
Re: Performance issue, pre boost
Mine did that , had a clogged fuel filter ...
1988 ST165 - 72K - Project ---> http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=31483&start=240
2000 Toyota Tundra SR5 - 150K - DD - Thanks 97JZA80
2007 Toyota Rav4 - 70k - My girls DD - Paid off !
88gt4DE - Established Member
UtahSleeper wrote: Plan on building a boost leak tester soon just to rule out air issues.
You could just take it to a shop with a smoke tester, best $30 you will ever spend.
It is a strange problem to have issues pre-boost but be ok in boost....have you checked your ignition components ?
4rsnduction - Club Member
over fueling perhaps?
1987 GT-S -> rust in piece
1991 RC -> project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=44216 "Darlinda the Tie Fighter"
1992 GT-S -> daily
2000 Cherokee -> ski hauler
1997 Prelude -> girlfriends daily/project "Charmeleon"
1992 GT-S -> daily
4rsnduction wrote:UtahSleeper wrote: Plan on building a boost leak tester soon just to rule out air issues.
Except this car is not registered/legal lol. So it wont be going to a shop anytime soon. Plus, a tester is good considering I will probably be doing this task on multiple vehicles in the coming years.
I did check plugs and wires visually. All seemed fine. Havent went deeper.
Overfueling..........no clue. Exhaust smells reasonable, so even if it is, I doubt it is that much. Still another option to check.
Background:
I bought this car non running and most things around the motor dismantled. I have put everything back to the best of my ability, but as I go through this car I am finding that there were things left installed that may have been tinkered with before me. So my knowledge of this car is as follows.
Bought 2 owners ago from someone in Idaho. Had a engine rebuild, but 2 owners ago thought it might have been poorly done.
1 owner ago dismantled alot under the hood. Had injectors cleaned. Never reassembled or said reason for dismantling, but did say head bolts werent tight and some other mechanical things I dont recall.
Me, I have reassembled and got her running with fresh gas. Checked everything visually during assembly, but no indepth checks.
Also, it revs fine. Just when trying to move it struggles.
• Page 1 of 1
Users browsing this forum: UtahSleeper and 0 guests
