Hi guys,
as title says I have few parts I will be getting rid of:
1) 3sgte GEN I engine complete, including the wire harness, intercooler, turbo, alternator, clutch, down-pipe (cat. converter) etc... - $350
original ST165 with 252K; the engine is a good candidate for rebuild;
Considering parting it.
2) ST185 tranny - $150
has new-ish seals all around, it shifted fine for all 5 gears except second where some grinding is noticeable when driven hard...nothing scary....just a bit annoying.
3) ST205 tranny - $50 (or free with ST185 tranny purchase)
has some problems, most likely the transfer case....
4) ST165 transfer case - free with any tranny purchase
good working condition...
5) ST165 (Alltrac) original wheels (14") - $60 (all 4) (or $20 each)
good-ish condition, normal wear and tear for that year
6) ST165 instrument cluster - $25
very good condition (still show the 252K...);
7) ST165 sunroof - $25
OK condition...some rust in one corner...
8) ST165 rear differential - $50;
original, would need new seals and/or output shafts bearings;
8) some odd ends.., front and rear struts and springs, engine mounts, starter, sensors, brackets, etc...
OR $520 FOR EVERYTHING ABOVE
I prefer local pick-up, (really don't have time for shipping).
I'm in Vancouver BC, Canada.
regards.
regards.
