Celica st202 3sge engine ecu and wiring loom connectors
Postby Snake19888 » Tue Mar 06, 2018 10:57 am
Hello, im searching for the Engine Wiring loom side Ecu connectors (the 4 plugs that come into the Ecu). I would also buy a complete wiring harness if its not that expensive, it must not be complete or can also have issues because i only need the 4 ecu connectors.
Also im searching for a NA gen3 3sge (175hp) Toms or Blitz, Sard and other upgrade Ecu. Dosent matter if MR2 or Celica only important is tjat its from the 175hp version without in the ecu integrated immobilizer.
Also i need the MAP sensor, Ignitter, ignition coil and squirters for the same NA 3sge gen3 engine.
Would be nice if someone have something, rhe most important first are the wiring loom plugs.
As other option for the ecu i would also take a gen2 (156hp) 3sge Toms, Sard and other uphrade Ecu also dosent mater if celica or mr2.
Cheers
Patrick
Snake19888
Images: 3
Re: Celica st202 3sge engine ecu and wiring loom connectors
Postby msanders2 » Tue Mar 06, 2018 11:20 pm
I have a gen3 3sgte engine harness for sale if that would help you? I dunno.
msanders2
Postby Snake19888 » Thu Mar 08, 2018 6:10 am
No sorry, gen3 3sgte does have different ECU Plugs. The gen3 3sgte has also 3 plugs the same as gen2. The gen3 3sge does have 4 plugs.. so it must be a gen3 3sge NA Wiring loom or only the Plugs is also ok.
Snake19888
Images: 3
Return to Parts Wanted
