ST165 PropRod Holder
Postby ___Scott___ » Mon Mar 19, 2018 3:36 am
I broke the holder for my prop rod (the rod that holds the hood up). It's the end where the rod pivots, not the clip end. I couldn't find all the pieces but did find enough to get some measurements. Thinking that with a little luck a 3D printed part may work, I gave it a shot. The 3D model looks like this:
You can download the STL file here if you happen to need one and have access to a 3D printer.
I used cheap PLA filament because that's what I had. I set the slicer up with 0.15 mm layer height, 100% infill with 3 vertical shells to create an almost solid part without voids.
The part snaps into position and holds the prop rod. Only time will tell how well it holds up.
EDIT to add a photo of the part in action:
Almost 24 hours and it ain't-broke-yet! :P
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
