Problem with Metra harness 70-8112 for a '90 ST185 w/sys 10
Postby Wreckless » Mon Aug 30, 2004 4:00 am
I found this cached page from the old forum on google:
http://216.239.41.104/search?q=cache:Gw ... ness&hl=en
Cliffs notes version: The Metra 70-8112 harness doesn't work on the 1990 models' System 10 setup.
My GF's is a 1990 with the System 10. Does anyone have experience with the Metra 70-8112 harness in a 1990? I know the standard two piece harness for a Toyota doesn't work because I had a spare one and it didnt fit at all.
I just need to install an aftermarket deck and keep using the stock amp. If this is possible to do and have all 10 speakers working, please tell me how I can without butchering the stock wiring. Thanks in advance.
1987 Supra Turbo 5-spd Hardtop silver/grey, 7M-GTE, 399rwhp, 428rwtq @ 18psi 91 octane.
1995 Supra SE Hardtop - black/black cloth, OBDII USDM 2JZ-GTE/ V160 Getrag.. single, fuel, cams, blahblahblah.
1990 ST185 - maroon/grey cloth. The ex kept it :(
Wreckless
Postby liveXwire » Mon Aug 30, 2004 6:11 am
Well actually with our setup in the 90 model, the standard toyota harness does work =}. When you have the unit out look to the back passenger side of the center console, and you should see 2 connectors. Those are what you'll plug the standard toyota harness into, your left and right channels. Now that will just run the 2 sets of component speakers. Now to get the drivers in the doors running, the best way I recall is to get a small amp and just find their wires going to the stock amp and wire that together. There are a few other ways to go about it though. I'm pretty sure celica.net has quite a few topics on it. Personally I just run to the 2 component sets in my car and haven't had the door drivers powered in years.
Colin
1990 Celica All-trac
1999 Impreza outback sport
1999 Mazda Miata
[img]http://i457.photobucket.com/albums/qq296/livexwire/alltracnetsig-1.jpg[/img]
liveXwire
