TODAY'S WORK:
1. Today's work began with borescoping the cylinders more thoroughly to inspect the cylinder walls and get some horrorshow pics of the carbon buildup on the cylinder faces and the valves. I got some good ones, that's for sure (pics 1 and 2). Based on what I saw, I resolved that soaking the cylinder faces with 1oz B-12/2oz PB Blaster/.5oz Marvel Mystery Oil was not going to get shit done. But it might help decarbonize the compression rings and oil control rings. Maybe. Eventually. So I put everything back together.
2. I ran LiquiMoly Engine Flush for 15 minutes at a slightly high idle of 1000rpm. I observed some smoke during the test (pic 3).
3. I dumped the oil at 103,700km. The oil had only been run for 444 miles, and even after having the LiquiMoly Engine Flush run through it, I could still see light through the exiting oil stream. It wasn’t fully opaque. I added 4 quarts of Valvoline 10W30 VR1, a bottle of LiquiMoly Viscoplus for Oil, and 4oz of SeaFoam (pic 4), bringing the oil level to the top fill hole on the dipstick. Viscoplus for Oil has the effect of stabilizing the VR1 10W30: “Our Viscoplus for Oil does not increase the viscosity of motor oil, it stabilizes the viscosity at hot temperatures and helps to keep the oil consumption at the lowest level."
3. I then took Roreri out on a drive, keeping it between 3000 and 5000rpm, for 61km. Throughout, I discovered a sure way to induce smoke: Clutch in coast followed by clutch out and throttle. I repeated this several times during that run, but interestingly it became harder to induce smoke toward the end of the run. I picked up a bottle of SeaFoam Spray before returning home.
4. I found an out of the way place to commit an ecological crime and ran the SeaFoam Spray through the throttle body. When I popped the hood I observed that the oil dipstick was out of battery, a sure sign of excessive crankcase pressure (pic 5). The smoke cloud from the SeaFoam Spray was, as always, alarming (pic 6), but I knew what to expect as I have done it before on a different motor. After running the SeaFoam Spray through the throttle body I sat and idled the motor until no more smoke was coming from the exhaust.
5. I then took Roreri out on the old Italian tune up, keeping it at 4000-5000rpm (pic 7), hard and tight with several 0-5000rpm pulls from a dead stop. My inspiration was Ken Miles:
I found it impossible to induce smoke, observing it just once and under an engine brake condition. When I returned home, I observed no smoke on idle and garaged it, having run it 100km after the lower end cleaning with LiquiMoly Engine Flush and 40km after the top end cleaning with SeaFoam Spray. The oil dipstick was very much out of battery, though, to the point where I could see the rubber o-ring (pic 8).
CONCLUSIONS:
Folks have suggested that the new CT16 turbo I installed might have a faulty CHRA. I am having trouble understanding how the oil would be getting to the cylinders with the turbo outlet pipe and throttle body being clean and dry. Plus, the dipstick being out of battery is such a clear indicator.
What I have observed so far leads me to the conclusion that the issue here is insufficient crankcase ventilation leading to excessive crankcase pressure leading to blowby or blowby leading to excessive crankcase pressure that the ventilation system cannot cope with. Chicken or the egg problem, really. I am hoping that it's curable by increasing crankcase ventilation, because with compression being 170psi (when adjusted from 7200 feet to sea level) that doesn't strongly suggest a compression ring problem. But a leakdown test will verify.
This problem resulted in oil contamination of the cylinders which led to carbon fouling. If not stopped this will result in the compression ratio being artificially increased and oil poisoning of the charge which will lower octane. Then, detonation.
In addition, excessive crankcase pressure is impeding oil flow from the turbo back to the oil pan when the motor is under boost. Not good.
WAY AHEAD:
1. I will reconnect the PCV valve output to the intake manifold vacuum port, with an inline one way check valve to prevent boost from backing up into the valve cover and crankcase. If the issue is related to excessive crankcase pressure I will have done considerable to address it. The PCV valve side will evacuate while the motor is under vacuum. The valve cover breather vent will evacuate constantly and SHOULD increase evacuation under boost.
2. I will conduct a leakdown test. I have this kit on order:
Free Shipping - Summit Racing™ Leakdown and Compression Tester Pro Packs with qualifying orders of $109. Shop Leakdown Testers at Summit Racing.
www.summitracing.com
3. I will continue to tune the M/E Wagner PCV valve and check it to be sure it is functioning.
4. If I absolutely MUST, I will install an electric vacuum pump and vent it to atmosphere with a filter low in the engine compartment.
5. I would like to find a way to gauge crankcase pressure in real time. You know, like an aircraft manifold pressure gauge. But for crankcase pressure. I guess I could rig up a hose to the top of the oil dipstick and snake the line out to a vacuum/pressure gauge taped onto the windshield!
6. I will double the octane boost dose I am adding to each tank of 91 octane as a safety measure.
7. I will stay on stage one of my electronic boost controller, which tops out at 11psi.
8. I will drive Roreri hard and tight, like I mean it. No less than 3000rpm, and gear changes at 5000rpm. The exception being while the motor oil at the cylinder head isn't yet warmed up. Good idle before shutdown to allow the turbo to cool and avoid coking.
9. I will change motor oil at 2000km (1242 mile) intervals, doing SeaFoam Spray and LiquiMoly Engine Flush before changing. I will add LiquiMoly Viscoplus and SeaFoam to the motor oil. Next change at 105,700km, then 107,700km.
10. I will borescope after two oil changes and engine flushes in 4000km.
11. I may choose to do the BG Dynamic Engine Cleaning service at any point during this.
