The shop, who just rebuilt my 1 year old, 15k mile old CT26 could not determine the true cause of why it failed. The only thing that they could realisticly suggest is that I may have an oil problem. The turbo is out right now, ready to go back in. I got a cheap oil pressure guage that I plan to temporarily hook up where the existing pressure switch is on the head ( the guage came with the correct fitting to do this in a snap).
Questions:
1: What kind of pressure should I realisticly see at idle and various RPMs?
2: Will the pressure reading off of the head be an accurate (enough?) indication of what kind of pressure the turbo is seeing?
3: Are there any other oil checks that I can do now since the turbo is out?
4: Anything else I should know / try?
The car is a stock '92 ST-185, with nearly 140,000 miles, running AMSoil 10W-30 Synthetic. Prior to this rebuld the turbo was a stock JDM CT26, freshly rebuilt. It has now been rebuilt to USDM spec w/ no upgrades (the ceramic was ruined and metal are much easier to find here).
Thanks in advance for your help!
Questions:
