zblu81":2qjdk3ku said:From what I understand, a MBC works by decreasing the vacuum signal for the wastegate to open so you can actually only increase boost with a MBC.
alltracman78":3mif754t said:zblu81":3mif754t said:From what I understand, a MBC works by decreasing the vacuum signal for the wastegate to open so you can actually only increase boost with a MBC.
Doesn't decrease it (unless you have a bleeder type bc=junk), only delays it. You can run stock boost with the mbc, but not below. Whatever boost you run, it will hit harder (spool up faster) with a bc, unless you have a new wg actuator.
