Hey I found this on a site today thought it was pretty usefull
http://www.yorksoft.co.uk/celica/gt4rc-mods.asp
btw, somebody can help to get rid off code 54, after fitting fmic in st185cs?
I keep getting code 54 Intercooler pump circuit.
Do you have a GT4RC complete ECU pin out as well?
ST185pinjo":y3lc2wym said:btw, somebody can help to get rid off code 54, after fitting fmic in st185cs?
Try pulling off the IC-ecu. It is located behind the radio.
I disconnect IC ecu, IC relay and bridge ic coolant sensor, no effect, code 54 still come.
Any toughts?
ST185pinjo":3hng60dp said:Do you have a GT4RC complete ECU pin out as well?
http://st165turbo4wd.hp.infoseek.co.jp/ecu_pinouts.html
Any toughts?
Disconnect the IC ecu(all connectors). Open the relay and clean the connections with sandpaper, then close and refit.
Did you reset the ecu(wires off the battery)?
