Cooling system diagram
• Page 1 of 1
Does ayone have a diagram of the cooling system they could post for me? I have a leak from a small u shaped rubber hose located next to the bottom heater hose. I have a bad feeling that it is going to be a real pig to get to so if anyone could help out it would be great.
Thanks
Thanks
1990 ST185
1996 Toyota Carib
New Zealand
1996 Toyota Carib
New Zealand
- Rider
Well after reinspecting the situation during daylight it turned out the defective hose was the one between the water bypass and the block. It was amazingly easy to replace compared to what I thought it would be, just needed a bit of bullying. However, I cant believe I missed when I was replacing hoses before the engine was installed.
I can also confirm that this diagram is identical for both st185 and st165 except for the oil cooler and the turbo cooling pipes.
1990 ST185
1996 Toyota Carib
New Zealand
1996 Toyota Carib
New Zealand
- Rider
Re: Cooling system diagram
this may be a old thread but thank goodness its still up! this is why i love alltrac.net
-1990 Corolla sedan (sky blue) totalled by my brother
•Daniel
•Daniel
- Awesome-Trac
- Established Member
If anybody still has this, would be greatly appreciated. Looks like the image finally broke!
92' SW20 MR2 Turbo 742 Aquamarine Pearl - 4th Gen 3SGTE Swap
92' ST185 749 Teal Metallic - Project "Pulled out of the Ground"
90' ST185 182 Graphite Metallic - SOLD! Wish I never did.
Tippo - Club Member
Don't know if this the pic that was posted before but this is the one that helps me
- dbucks2k
dbucks2k wrote:Don't know if this the pic that was posted before but this is the one that helps me
Awesome! Thank you!
Tippo - Club Member
• Page 1 of 1
