Cooling system diagram
Postby Rider » Thu Jan 06, 2005 3:27 am
Does ayone have a diagram of the cooling system they could post for me? I have a leak from a small u shaped rubber hose located next to the bottom heater hose. I have a bad feeling that it is going to be a real pig to get to so if anyone could help out it would be great.
Thanks
1990 ST185
1996 Toyota Carib
New Zealand
Rider
Postby Gary » Thu Jan 06, 2005 8:17 am
93 ST185
Gary
Postby Rider » Thu Jan 06, 2005 8:41 am
Cheers Gary, thats brilliant - exactly what I was after. Looks like its one of those damn dirty throttle body coolants hoses that is toast. Time to ditch the TB cooling then.
1990 ST185
1996 Toyota Carib
New Zealand
Rider
Postby Gary » Thu Jan 06, 2005 9:58 am
Your welcome.
By the way, the picture is from the ST185 manual.
Not sure if it differs from the ST165.
93 ST185
Gary
Postby etantshi » Thu Jan 06, 2005 10:59 pm
I believe it is the same. Except for the oil cooler.
André B.
1991 ST185 (down but not out)
1990 ST185 (lost, but not forgotten)
1996 RZN140 (the daily)
2004 Yamaha R6 (needs a battery) - sold
etantshi
Postby Rider » Sun Jan 09, 2005 4:28 am
Well after reinspecting the situation during daylight it turned out the defective hose was the one between the water bypass and the block. It was amazingly easy to replace compared to what I thought it would be, just needed a bit of bullying. However, I cant believe I missed when I was replacing hoses before the engine was installed.
I can also confirm that this diagram is identical for both st185 and st165 except for the oil cooler and the turbo cooling pipes.
1990 ST185
1996 Toyota Carib
New Zealand
Rider
Postby Gary » Sun Jan 09, 2005 1:30 pm
Good to know it's an easy fix. :)
93 ST185
Gary
Re: Cooling system diagram
Postby Awesome-Trac » Mon Dec 16, 2013 7:49 am
this may be a old thread but thank goodness its still up! this is why i love alltrac.net
-1988 Celica Alltrac (white) Sold
-1988 Celica Alltrac (black) new project
-1990 Corolla sedan (sky blue) totalled by my brother :(
-1990 Celica GT-S hatchback (sky blue) daily driver
•Daniel
Awesome-Trac
Postby Tippo » Thu Apr 01, 2021 10:55 am
If anybody still has this, would be greatly appreciated. Looks like the image finally broke!
92' SW20 MR2 Turbo 742 Aquamarine Pearl - 4th Gen 3SGTE Swap
92' ST185 749 Teal Metallic - Project "Pulled out of the Ground"
90' ST185 182 Graphite Metallic - SOLD! Wish I never did.
Tippo
Postby dbucks2k » Sat Apr 03, 2021 6:12 am
Don't know if this the pic that was posted before but this is the one that helps me
dbucks2k
Postby Tippo » Sat Apr 03, 2021 11:48 pm
dbucks2k wrote:Don't know if this the pic that was posted before but this is the one that helps me
Awesome! Thank you!
Tippo
