Compression Test Results
Postby superalltrac » Mon Aug 16, 2004 8:38 pm
So guys I just did a test on my engine and the results for all 4 cylinders are 140-142 psi dry, after a few drops of oil up to 160 psi give or take. Let's hear what you guys have to say on what to do.
thx :shoots:
Trevor,
1988 ST165 (ST185 turbo)
283,000 kms and still going
(well somewhat, haha)
superalltrac
Postby Gary » Mon Aug 16, 2004 8:43 pm
Look fine to me, little low but still in the spec.
ST185 compression spec:
164 psi or more
minimum: 128 psi.
diff between each cylinder: 14 psi or less
93 ST185
Gary
Postby toayoztan » Tue Aug 17, 2004 12:48 am
Looks a little low to me too. the wet test jumped a bit, but not enough to have blown piston rings (i believe it has to be around a 30psi jump?). Anyway, I guess it just suggests you have a bit weak piston rings...not blown though.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby mototebok » Tue Aug 17, 2004 9:49 am
Numbers look good for a ST165
-Adam
'88 Alltrac .... Got a shiny new turbo
'94 RX7 .... Other money black hole
'00 ZX6R .... Lime Green Speed Machine
mototebok
Postby ChrisD » Tue Aug 17, 2004 2:02 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby superalltrac » Wed Aug 18, 2004 12:59 pm
thx guys.
Chris, no real plans just checking on the shape of the engine. I'll probably drive it till it dies then rebuild everything.
Trevor,
superalltrac
