Axle Nut Torque: 166 or 137
Re: Axle Nut Torque: 166 or 137
Postby RafaCalde » Tue Mar 20, 2012 3:09 pm
Those of you just using impacts, I have a question for you. Do you daily drive your car? I do and once I just used the impact and the nut still backed out. And it was a good impact. I recommend still using a torque wrench to ensure proper torque after impacting it down. Just be safe.
Rafa
RafaCalde
Postby tubasteve » Tue Mar 20, 2012 4:17 pm
RafaCalde wrote:Those of you just using impacts, I have a question for you. Do you daily drive your car? I do and once I just used the impact and the nut still backed out. And it was a good impact. I recommend still using a torque wrench to ensure proper torque after impacting it down. Just be safe.
I do know that about 10k cars we've done axles on and wheel bearings on. 0 have come back due to impacting on. We have line pressure alarms when below 140 psi constant line pressure to ensure the same performance everytime. I've seen more axle nuts back off when tq'd to spec. I'M NOT SAYING IT'S A BAD IDEA, just sharing experience. If the axle nut is used once already, you should be over tq'd just a little bit. Trust me.
-jr
tubasteve
Postby bridge47 » Tue Mar 20, 2012 5:50 pm
How is it that the nut can be backing off? The factory retainer and pin should keep this from happening. Do not all models have this? My 90 did and IIRC, so does my 93.
Another word about torque values. I would imagine the 166 ft lb refers to clean dry threads. After so much time and miles it is likely that nut won't spin on easy so torquing to 166 could actually be less. In this case over torquing nut a bit is not a bad idea.
Facts are stubborn things.
bridge47
Postby tubasteve » Tue Mar 20, 2012 6:50 pm
On my red car it took the castle off when backing off, I'll see if i can find pictures...
The pin sits out a little, and once the castle is sheared...it's too lose to support the bearing.
tubasteve
Postby tubasteve » Tue Mar 20, 2012 6:57 pm
^ mind you, this happened twice, same spindle, new hub and bearing with axle. It was checked several times for 1k miles just to bake sure it stayed tight, and hadn't backed off even with track days. The previous owner appeared to have same problem as they peened the hub...
The new axles I'm getting are coming with a new axle nut/washer combo like Honda but still uses retainer and cotter pin. Been having great luck with these i must say.
tubasteve
Postby jonahs_3sgte » Tue Mar 20, 2012 7:27 pm
i always use impact to torque down with and never had a issue with the nuts back off
now on my 90 gts i installed new axles and wheel bearings
torqued to i believe 150ft lbs(did this 2 years ago)
1 week later i felt a little in my front end
got home and inspected
found the axle nut and shaft completely broke off and was missing lol
new axle and impact torque later...she was good til i sold her
1988 ST165...66,000 miles
2009 Corolla
1999 Ranger
jonahs_3sgte
Postby RafaCalde » Wed Mar 21, 2012 1:08 am
-jr
I agree with you completely. I was just suggesting cause it's happened to me twice. You know how we are on here. We learn from others mistakes and misfortunes. :doh: :D
bridge47 wrote:How is it that the nut can be backing off? The factory retainer and pin should keep this from happening. Do not all models have this? My 90 did and IIRC, so does my 93.
I've had the nut back off even with the retainer and cotter pin in.
Rafa
RafaCalde
Postby bridge47 » Wed Mar 21, 2012 5:44 pm
^^ The only way that the nut could back off loose enough to destroy castle retainer is...
Nut has been over tightened in the past, thus distorting threads, or...
Torque wrench is:
-Out of spec.... get it calibrated.
-Not used with proper methods. IE; 166 ft lbs is a lot of torque. So one has to have someone pressing on the brakes and sometimes a large steel bar in between lug nuts trapped into the ground in order to reach 166 ft lbs with arm at 90 degree angle to torque wrench upon final click.
Like tubasteve, I've tightened hundreds of these, both impact and torque wrench. Not a single comeback.
In short; recheck your methods.
bridge47
Postby Corey » Sun Jan 13, 2019 6:18 pm
It's been some 7 years and 70,000 km since I had the front wheel bearings replaced and started this thread.
Here's an update:
Front left bearing is completely destroyed. Wheel very visibly tilting up and down, even with full weight on the wheels. If I pushed on the top of the wheel I could hear, feel and see the wheel tilt inwards.
Noticed the locknut cap fins had been bent by the cotter pin indicating the nut had backed out.
Went to remove the axle nut with the breaker bar and it pretty much came off in my hand.
In the process of replacing both front bearings now with new hubs. I torqued the axle nuts to 180 ftlbs 7 years ago which was between the ST205 and later ST185 spec.
This time I'm going to torque them to the ST205 spec of 195 ftlbs and will be more diligent about re-checking the torque each year.
Corey
Images: 50
Postby underscore » Sun Jan 13, 2019 8:33 pm
This has me wondering what mine were torqued to at the shop, I think I'll double check them the next time the wheels are off since this seems to be a fairly common problem. I'm not a fan of just hammering them on with an impact as too tight will cause longevity issues too.
Postby Corey » Thu Jan 31, 2019 12:25 am
Did some research into what other Toyota cars use for their axel nut torque.
In youtube videos I saw that the Corolla is 217 ftlbs, and on MR2OC they are talking about 217 ftlbs.
So, considering the ST205 is already 195 ftlbs, I decided to go with 217 ftlbs. Nothing snapped off so hopefully this will keep the nut from backing off. Still going to check every 10K or so I think.
Corey
Images: 50
Postby Rick89GTS » Fri Jan 24, 2020 4:31 am
Jesus. I torque my ST165 to spec at 137 ft lbs but now gonna check and torque them up higher
Rick89GTS
Postby FC Zach » Fri Jan 24, 2020 9:39 am
Something else to consider is the threaded diameter, I've had two different sizes with reman front axles. . My guess is the '92 and '93 had the larger size, which might explain the difference in torque?
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
