I need to smog my car here in ca, its also not running well so rich. This is the first emission testing since two years ago when I got the car running.
So everything has 7k miles on it, had new o2 sensor, new plugs, wires, cap and rotor, new cat. Running oe ecu.
I have a wideband on it so I know what Afr it runs.
When its cold it runs 14.7 to 15 when at idle and cruse. After it is driven for a while at op temp it starts to run rich. As rich as 12-11.5 at idle and cruising.
As far as I can tell the AFM and o2 are good. How can I be sure, I will post some videos later.
