Abs light comes on at higher speeds
Postby lalojamesliz1 » Tue Jul 17, 2018 2:34 am
If I go past last say 85mph my abs light comes on. When I turn off my car and restart it the light will be off until the next time I get to that speed. I have 225/50r16 tires on now if that helps
08 sequoia 5.7L
14 avalon
02 taco dbl cab V6 turd
and a 2 car garage :shoots:
lalojamesliz1
Re: Abs light comes on at higher speeds
Postby 93celicaconv » Fri Aug 24, 2018 11:26 pm
lalojamesliz1 wrote:If I go past last say 85mph my abs light comes on. When I turn off my car and restart it the light will be off until the next time I get to that speed. I have 225/50r16 tires on now if that helps
If your ABS Warning Light comes on, it typically sets a diagnostic code. Have you gone through the process of jumpering the Tc & E1 terminals of your check connector to see what the blinking code of the ABS light is telling you?
If you need help with the process and/or how to read the resulting code, let us know.
93celicaconv
Images: 26
Postby lalojamesliz1 » Fri Aug 24, 2018 11:50 pm
I didn't know i can check it by jumping Tc and E1. I'll look into that. Thanks :)
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby 93celicaconv » Fri Aug 24, 2018 11:58 pm
Yes, you certainly can.
ABS systems have a service connector running horizontally just behind the check connector (towards the firewall, slightly towards the center of the car). That needs to be disconnected prior to jumpering terminals Tc & E1 of the check connector.
If the ABS blinks continuously every 1/2-second, there is no code stored. Otherwise, there are 19 possible 2-digit trouble codes the ABS light will flash out regarding what it thinks the problem is. There could be 2 or more codes, so make sure you observe them all.
93celicaconv
Images: 26
Postby lalojamesliz1 » Wed Jun 12, 2019 12:40 pm
Almost a year later I finally remember to check this :P
A friendly race with a Hyundai veloster (close but I got him) got my light to come on and since I had a little time I checked for my code.
Abs code 32...... left front wheel speed sensor correct?
I remember seeing that the 90's camry sensor works with light modifications. Anyone familiar with using these sensors?
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby One-TracMind » Wed Jun 12, 2019 1:00 pm
See my post at the bottom of this thread here:
viewtopic.php?t=53145
One-TracMind
Postby lalojamesliz1 » Wed Jun 12, 2019 1:20 pm
One-TracMind wrote:See my post at the bottom of this thread here:
Thank you for sharing that :D
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby 93celicaconv » Thu Jun 13, 2019 9:53 am
ABS DTC 32: Front left wheel speed sensor signal malfunction
There are 3 areas to check for the cause:
1 - speed sensor
2 - sensor rotor
3 - wire harness and connector of speed sensor
I wouldn't focus on only one of those three causes. In fact, if your ABS DTC only comes on after traveling a very high highway speed (85 MPH), I would tend to focus more on item 3.
The BGB has an excellent 4-page "Speed Sensor Diagnosis" that would definitively tell you if item 1 above is at fault. If after completing all the steps in that 4-page diagnosis guide, if everything checks out, you could rule out the sensor. If a fault it obtained during this diagnosis, you could pinpoint the problem to the sensor.
93celicaconv
Images: 26
Postby lalojamesliz1 » Thu Jun 13, 2019 10:09 am
93celicaconv wrote:ABS DTC 32: Front left wheel speed sensor signal malfunction
1 - speed sensor
2 - sensor rotor
:D
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby Rick89GTS » Sun Jul 14, 2019 4:38 pm
Good thread, gotta check mine too. Thanks
Rick89GTS
