88 all trac falls on its face under acceleration
Re: 88 all trac falls on its face under acceleration
Postby lt2fire » Mon Sep 10, 2018 3:29 pm
Have not checked yet because I couldn't find my multimeter anywhere.... just got a new one.
lt2fire
Postby FC Zach » Tue Sep 11, 2018 4:03 am
If you need the specs, I'll look at my manual and share them here.
1992 Toyota Celica AllTrac
1993 Yamaha GTS1000
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby lt2fire » Tue Sep 11, 2018 4:15 pm
FC Zach wrote:If you need the specs, I'll look at my manual and share them here.
Could you do that please?
For the life of me I can't find it in my Factory service manual. It tells me to go to a page that isn't there. I must have downloaded an incomplete one.
lt2fire
Postby FC Zach » Tue Sep 11, 2018 4:29 pm
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby lt2fire » Tue Sep 11, 2018 6:13 pm
Thanks....
lt2fire
Postby lt2fire » Tue Sep 11, 2018 6:25 pm
FC Zach wrote:Image
Thanks, those are testing for door closed right? Is there a test for door open also?
lt2fire
Postby FC Zach » Wed Sep 12, 2018 1:19 am
Yes, I believe so. . I saw no mention of anything other than testing with meter.
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby lt2fire » Wed Sep 12, 2018 1:28 am
Ok so it seems to check out.
279
286
2.6k
Infinity
Was my readings
lt2fire
Postby lt2fire » Wed Sep 12, 2018 2:33 am
So I was poking around and found a hard vaccum line that is either missing a cap or a line and a line near it that is looped to another one that just doesn't look right to me. I pulled up a vacuum diagram but it isn't showing the two lines that are looped only one??
I also found a sensor that isn't connected to anything.
So the big question is what are these?
lt2fire
Postby FC Zach » Wed Sep 12, 2018 3:09 am
I may be wrong but I believe your looped vac ports are for the EGR system. . the vacant tube originally would have connected to the passenger side port (P) and the left (E) one would have connected to a solenoid.
Mine are capped but I guess looping them is the same?
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby dbucks2k » Wed Sep 12, 2018 3:10 am
Those two vacuum lines looped together, one goes to the vsv for your charcoal canister and one goes to the vsv for the egr valve. I don't remember what that sensor is for though.
dbucks2k
Postby dbucks2k » Wed Sep 12, 2018 3:12 am
Actually I just looked at my spare parts. Looks like that sensor is the temp sensor for the egr valve.
dbucks2k
Postby FC Zach » Wed Sep 12, 2018 3:14 am
dbucks2k wrote:Actually I just looked at my spare parts. Looks like that sensor is the temp sensor for the egr valve.
I was about to say the same.
1993 Yamaha GTS1000
FC Zach
Images: 9
Postby lt2fire » Wed Sep 12, 2018 3:18 am
FC Zach wrote:I may be wrong but I believe your looped vac ports are for the EGR system. . the vacant tube originally would have connected to the passenger side port (E) and the left (E) one would have connected to a solenoid.
So that sensor is the EGR temperature sensor..... so if it is plugged in and sitting there reading just the temp of the engine bay what would that do.
The EGR has been removed (I just got the car so i'm still learning this engine)
if that one hard line isn't hooked up to wear it is supposed to be i'm wondering what that would do?
And When poking around to make sure the EGR was all gone I found another sensor that seems like it should have a line or something coming off of it.
So now the next question is what is this?
https://scontent-sea1-1.xx.fbcdn.net/v/ ... e=5C29CAAC
lt2fire
Postby FC Zach » Wed Sep 12, 2018 3:36 am
lt2fire wrote:if that one hard line isn't hooked up to wear it is supposed to be i'm wondering what that would do?
Do you still have a charcoal canister? Either way. . If it's not connected properly or the entire system is missing, you could smell gas fumes from the tank (my guess).
lt2fire wrote:And When poking around to make sure the EGR was all gone I found another sensor that seems like it should have a line or something coming off of it.
Where is this located? or was it just loosely laying?
1993 Yamaha GTS1000
FC Zach
Images: 9
