finally going to attempt to replace rear bushings
Re: finally going to attempt to replace rear bushings
Postby 93celicaconv » Sun Mar 03, 2019 12:27 pm
lalojamesliz1 wrote:this is all I have now. just lube them and push them in right? if they need to be pressed in, I'm screwed
Where did you get your subframe bushings from? How are they working for you (compared to your original rubber bushings)?
I see the answer to my first question later in your thread. Just want to know how the rear subframe bushings are working for you - I know you said the clunking is gone - how is the ride? More harsh? Softer? About the same?
93celicaconv
Images: 26
