Does the shifter have replacement bushings?
Re: Does the shifter have replacement bushings?
Postby alltrac801 » Wed May 29, 2019 2:51 pm
Sorry I totally spaced taking that picture last night but I will do it tonight and I downloaded that app so I will try to get that picture on here tonight for you.
alltrac801
Postby lalojamesliz1 » Wed May 29, 2019 8:41 pm
alltrac801 wrote:Sorry I totally spaced taking that picture last night but I will do it tonight and I downloaded that app so I will try to get that picture on here tonight for you.
No worries man. Take your time.
08 sequoia 5.7L
14 avalon
02 taco dbl cab V6 turd
and a 2 car garage :shoots:
lalojamesliz1
Postby alltrac801 » Thu May 30, 2019 12:29 am
Okay so I think I got this picture stuff figured out!
This is the end of my cable that broke.
alltrac801
Postby lalojamesliz1 » Thu May 30, 2019 1:53 am
Thanks for posting these. So the cable end was pulled out after a few strands broke huh. I was talking with a couple of my welder friends about tig welding the ends and one recommend brazing with copper rods and flux to keep the cables in before they break.
Does that sound like a bad idea?
The transmission end of the cables are magnetic so not aluminum. Not sure yet on the ends that broke on you.
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby alltrac801 » Thu May 30, 2019 4:04 am
No problem. It kept getting harder and harder to get the car into 2nd so one day I forced it into second and that was the last straw lol I dont know if welding it would be a bad idea or not. I know there is a set of ST185 cables used on EBAY right now for just over $200 if you do end up needing a set.
alltrac801
Postby lalojamesliz1 » Thu May 30, 2019 4:14 am
I hope I don't need them. I'm waiting for my bushings to arrive so I can try that then I'll know.
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby Magroo » Fri May 31, 2019 12:09 am
I got curious about this bushing and checked for some part numbers.
I forgot to inspect mine today cause I was too busy wrapping my exhaust downpipe to try and get some control over how hot my engine bay is.
33557-33010
https://www.toyotapartsdeal.com/oem/toy ... 33010.html
Magroo
Postby lalojamesliz1 » Fri May 31, 2019 12:31 am
This covers the st85? I'm asking because it doesn't have it listed. Thanks for checking :D
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby Magroo » Fri May 31, 2019 12:34 am
Honestly I'm not sure. I just went looking for 3sgte sugarcube and this is what came up.
Magroo
Postby alltrac801 » Fri May 31, 2019 2:58 pm
GT4-Play actually has a replacement sugar cube if that's all you're looking for.
https://gt4-play.co.uk/shop/gear-select ... sugar-cube
alltrac801
Postby Magroo » Fri May 31, 2019 4:26 pm
Actually remembered to check out the sugarcube today and its toast.
Magroo
Postby alltrac801 » Fri May 31, 2019 4:34 pm
That's about what mine looked like so I rotated it 180 degrees to the unworn side. I regret not just buying a new one at the time because it was kind of a pain to get to at the time.
alltrac801
Postby lalojamesliz1 » Fri May 31, 2019 4:59 pm
Magroo wrote:Actually remembered to check out the sugarcube today and its toast.
Good thing you found that. Before I installed the e154f trans I looked at the cube and it's like new but some kind of plastic instead.. I'd try to get the newer plastic ones if possible.
08 sequoia 5.7L
14 avalon
lalojamesliz1
Postby underscore » Fri May 31, 2019 5:27 pm
alltrac801 wrote:That's about what mine looked like so I rotated it 180 degrees to the unworn side. I regret not just buying a new one at the time because it was kind of a pain to get to at the time.
If the first side lasted you that long though you should be good for a while.
Postby alltrac801 » Fri May 31, 2019 5:32 pm
underscore wrote: If the first side lasted you that long though you should be good for a while.
That's true. I'm sure the cube had just as many miles as my car does! So I have another 200,000 miles before I need to replace it lol
alltrac801
