No Fuel
Re: No Fuel
Postby fvkagi » Mon Jul 08, 2019 2:52 am
The fuel supply is fine, we tested it with the line off. I am also going to start a new thread for the idle issue eventually. It will rev high but the car wont start without giving it some throttle. And when you give it rpm and let off the gas it slowly goes down to idle rpm then dies once its there. I saw some other threads that had extremely similar issues and all of those people had vacuum leaks, so I just assumed lol
fvkagi
Re: No Fuel
Postby 93celicaconv » Mon Jul 08, 2019 10:33 am
Best to start a new thread on the new subject then, now that the issue involving this thread is resolved.
Only way to have your current issue is to have a massive air leak into the intake system downstream of the MAF.Have you had any of the air ducting from the air filter to the the throttle body off and this current problem started sometime after that?
93celicaconv
Images: 26
