ST215 swap people
ST215 swap people
Postby UtahSleeper » Sun Jul 28, 2019 3:30 am
For those of you that swapped a 215 into your ST165, does your coolant temp gauge work correctly? I ask cause my gauge only goes 1/4 up then stops, but the ECU shows an accurate temp (torque). Not sure if I need to add the original temp sensor or if it could be the cluster.
UtahSleeper
Re: ST215 swap people
Postby JRWperformance » Fri Sep 27, 2019 11:11 pm
Mine works fine. I had my wire harness done by WireGap. Its using the stock sensor that came with my engine.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
