Nickzendar
Member
So earlier this summer when I was driving I would periodicly have the check engine light appear when driving but it would only last for a second before going away. It would also appear when starting the car but would go away as the car warmed up. I eventually suspected a missfire and changed the plugs but that did not make a difference. I have newish NGK leads so I then suspected the distributor to be the problem. I swapped out the rotor and cap only to find that the car wouldent start. Im receiving power to the center lead and I can smell the gas comming out the tail pipe but the car wont start. I checked to see if im getting power to the leads and I am not. I have tried two other rotors and the original cap but the only thing I have yet to try is the original cap and rotor. Am I doing something wrong?
