Alternative For Expensive OEM Relays
Re: Alternative For Expensive OEM Relays
Postby Roreri » Thu Aug 18, 2022 6:18 pm
Super glad to not have ABS. Condolences.
Roreri
Postby 93celicaconv » Fri Aug 19, 2022 10:36 am
If that replacement ABS relay doesn't solve your problem, there are codes for the ABS system (I think) that can be accessed by jumping two terminals on the diagnostic port. There is for the engine ECU and the cruise control system anyway. If you need help with that, just ask.
93celicaconv
Images: 26
Postby supra-raleigh » Mon Aug 22, 2022 1:40 am
Thanks guys for the great advice. However, the ABS light now comes on and then properly goes out a few moments after the car starts. Hopefully, the car is just working itself back to normalcy since it was sitting dormant for 3 and 1/2 years.
For now, I will just put this ABS module with my other spare fuses and relays that I keep in the trunk.
none
supra-raleigh
